tombr77
Model 1067 differntial lost limited slip feature
pfrederi
How much weight do you have on the tractor.  What kind of chains are you using?  Turfs or Ag tires?  Uphill on wet sow and smooth surface is a challenge with out chains and lots of weight.
Edited by pfrederi
tombr77
about 25 # on each side, have tried chains, they grip in snow, but not good on slick pavement - which is what i have behind the plow blade..  its 20 to 30 degree hill, -- i used to be able to plow 3-4 inches of snow going up it  ( which is very impressive)-- before the limited slip gave out.
pfrederi
That is a steep hill.  With my Charger (Ltd Slip) I run 70 lbs on each wheel and 55 on the drawbar plus chains.  You might consider rubber chains on asphalt.  Other thought...plow down hill gravity is your friend.  The hill down t0 my barn isn't that steep and i take a full blade width down but only a fraction coming back up.
Edit:  As I said before in my opinion a working 10 pinion will out plow an open differential any day,,,but the open ones can do a good job with adequate weight and traction enhancers.
Edited by pfrederi
stevasaurus
You could take a black magic marker...draw a line across the hub and axle on both sides.  After driving it, see if the line is still straight.  :)  To easy to not try.
pfrederi
 It pains me to admit it but there is one other possibility.  A couple years ago my L107 that my father bought new in 1967 started to slip going up a slight grade.  I figured the 40 year old belt had lost its grip... Wrong!!  Neither was it the hub or woodruff keys axle or input shaft.....
Turns out one of the rear tires had  lost air pressure.  Sidewalls were stiff enough in the winter so you would not notice.  The bead had broken and the wheel would slip in side the tire... not an every day occurance
formariz
Even though I have used the Electro for quite a few years now, I am always learning something about it. I also have a 30% grade driveway with paving blocks. A couple of weeks ago for the first time pushing a little snow up the driveway all of a sudden in the middle of it, right wheel starts spinning like crazy and left wheel just stopped. This is with chains and 50Lbs on each wheel. I have no idea why? Today with 4" plus of snow full plow going full blast up driveway no slipping whatsoever, same machine as always. I have no idea what happened before, but thought the same had happened as it did to tombr77.
tombr77
plow down when i can - but hill down from house,  fairly flat length then an uphill - so no matter where i start, there is a 30 degree up hill to tackle- an if i cant get up it even with plow raised, i cant plow down it.  I will look into larger wheel weights.   Anyone ever fill their tires ( like on farm tractors)?
Sarge
You can , as some others have done fill the tires - but there is a catch . All the added weight inside that tire can transfer some serious traction and on the older frames break the rear mounting plate (mine is broken now, 2nd time ) where the transmission is bolted to the frame . They can be fixed and reinforced , but the traction can create so much stress to the rest of the tractor eventually something will give . The more traction you give it , the more you can work it , and the more you can break it . I've weighted my rear tires to 145lbs total which is really pushing it .
If you go with 50lb or greater wheel weights and maybe use the rubber chains it should make a huge difference . Garden tractors really aren't designed to run up a steep grade so a lot of caution is necessary .
One huge factor you have to know about - the Kohler engine . It's operating limit is 25* , as specified by Kohler . If you turn around or something on that grade and "side hill" that engine you'll starve the oil splash to the rod , which it won't take but a few times and the rod will destroy itself and possibly the crank/block in the process . It's the only major drawback on the older splash lube K series single cylinder engine - otherwise , they are perfect . I have never found any reference as to forward/backward angles against them , not sure if the 25* operating angle applies to just side tipping or if it also applies to forward/back angles ....
Anyone ever found an answer for that ?
Sarge
tombr77
sarge = thanks for the 25 degree limit on Kohler... Ive replaced the rod & crank before, (before i had this hill :) ) and dont want to do it again.  I will get a better measure of the incline !   I will also look for the rubber chains -- that   along with a little more weight sounds like the easiest solution to try first...{ especially if i cant find / make a new C spring}
As a side note, i also replaced the cam shaft --- turn out when i bought it 30 years ago, the opwner had just had it rebuilt -- and said it had 'way more power that before.   After I rebuilt ( broken camshaft) And was setting the max RPM i figured out why - the previous guy had mounted it incorrectly,so full throttle would over rev about 2x.!!!  it put up with this for about 20 years before finally saying 'no more'!!
953 nut
Never knew the limit, but got a great buy on a parts tractor once because of this, P.O. had always mowed up and down his long hillside, his son mowed across it once and it developed a knock; told him what had happened and he gave it to me for $ 50 because it was "going to cost too much to fix it". One :techie-ebay:kit and a few hours of work and I had a good running 12 HP for the project I was working on.
  • Similar Content
    • tomabrown77
      By tomabrown77
      my 1067 stopped moving; limited slip had worn out long ago;  now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance.  Enough to tell me shift lever is actually changing gears.
      I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt  transaxle if someone has one they would part with.  And any advice on opening up the transaxle and looking inside .  Or where i can find parts to rebuild it myself...
      ps i was on forum about 5 years ago,  forgot my username so i joined again
    • sfjohnson722
      By sfjohnson722
      Greetings all, first post to this forum.
      I am in the process of getting my father's 1971 Bronco 14 (1 0421 6) up and running. After pulling the hydrogear for reworking, I noticed some lash between the rear wheels when on jackstands. I found one of the hubs to be badly worn, but also noticed there seems to be a clicking or ratcheting when turning one side at a time (whether the parking brake is on or off). The opposite wheel does turn in the opposite direction - it just does so with a click / ratchet feel. I was expecting something smoother like with an automobile differential. Is this normal? Should I plan to split the case, and if so what should I be looking for?
      Thanks in advance for any information!
    • WHX??
      By WHX??
      Started this refresh a couple of months ago and have made a little progress but things are stating to shape up now so thought I would do a thread. 'Sides I need some help & advice!
      Little history first
      This is a 1967 1067 with the original K241 10hp. This tractor is somewhat special to me as I bought it as my first wheel horse in 1986. I had just started renting an old farm house which had quite a large lawn that I would be required to mow. I mentioned this to a buddy who told me of a riding lawn mower that he saw for sale. I went and looked at it and paid 350 which in the day was quite a bit of coin, for me at the time anyway as I was making only $5.50 an hour servicing dairy equipment! Wasn't the prettiest  but it started right up and cut so I brought it home. Never would have guessed 31 years later I would have this WH monkey on my back!  I new absolutely nothing about a Wheel Horse & keep in mid there was no such thing as the internet back then. After about a year I needed parts and someone told me they were no longer made. I contemplated scrapping it but then someone said to check Toro dealers for parts. All I needed was blades and some bearings. The first dealer I went to wasn't much help as they wanted me to cobble other parts on it and I didn't want to cobble any more on it than what had already been done. 2nd dealer I went to wasn't much help as they wanted to sell me a new 3,4 or 500 series! Must admit they did look nice on the showroom floor but given my tax bracket at the time wasn't likely to happen. The idea of scrapping came up again but I persisted and  kept it running and mowing. Threw a rod in the 241 about 1994 but went thru the motor and fixed that. about 1997 another buddy had a Toro branded 246h for sale that took over mowing duties. So the old 1067 went into hibernation for 20 years. Every now and then I would throw a battery in it and it would ALWAYS fire right up. Fast forward to about two years ago and I decided I was gonna getting running again and use it. After searching the 'net for parts I stumbled on this thing called Red Square. Well after reading a here about RJ's, Suburbans, 953's, & 857's I quickly caught the bug! Eight  or ten  horses (OMG I lost count ) later I finally said this old girls time has come. @stevasaurus had mentioned this had a ten pinion 5060 LS transmission in it and might make a good plowing tractor.
      The axle seals were leaking bad, the hubs were walking on the axles & front end had homemade tie rods not to mention a myriad of other issues.....but thanks to RS, parts I had spied at the BS, and the knowledge of those here I knew  this was savable. My intent is not a trailer queen nor a show tractor but a nice working tractor for some light field plowing, having fun at shows, moving boats & trailers around the ranch and perhaps some kids in a tub. I seriously doubt it will ever see mowing duty again.
      'Nuff yaking and on to the before  pics!
      After looking at these ..no where near as bad as some I have seen here!
      Tranny disassembly pics...not too bad 1533 were usable but since now they can be had.
      Note the water line!
    • Al C.
      By Al C.
      I've got a Wheel Horse 1067 with a Kohler 10hp engine.  The engine runs fine.   Starts right up,  No smoke.  Doesn't burn oil.  The problem I have is that there is always a "wet" film of oil just below what I believe is the fuel pump.  It never drips, but seems to seep out very very slowly.  I probably lose an ounce of oil a year.  My questions are ... what is the likely source of the seepage; am I asking for trouble if I don't correct it;  what is the likely solution; and how difficult is this?  I have attached some pictures to give a better idea of what I'm talking about.  Appreciate your thoughts ...
