thehorse 221 #1 Posted December 18, 2016 After installing and using the blower for sever years, I thought I had everything down to a science. I hooked blower up to 416-h a few weeks ago and moved to garage in preparation for snow. I had to move tractor around yesterday and when raising the blower, it sounded as if something was binding. After which, the blower will only lower to about an inch off the floor. I'm not sure if it was able to go the whole way to the floor before it bound up some. The gauge depth wheel is up and out of the way. Any ideas?? Share this post Link to post Share on other sites
lynnmor 6,775 #2 Posted December 18, 2016 Sounds like you used the wrong hole. Go back over the instructions and double check. Share this post Link to post Share on other sites
GlenPettit 1,714 #3 Posted December 18, 2016 (edited) Check your tire pressure also, the cold Winter air can drop it 2–3# easily, consider 20# in them (may give an extra 1/2" height). Edited December 18, 2016 by GlenPettit Share this post Link to post Share on other sites
