dambur
I have a 204 4SB runs fine in reverse and lower gears when i put in in the highest gear it creeps forward then may at some point gain momentum?
pfrederi
Are you sure about your model #.  ???
dambur
42-08B401
208-4SB
Image result for WheelHorse 208-4SB
gwest_ca
Slips in high gear is the classic complaint when a clutch starts to slip. In your case it would be the drive belt. A slim chance would be a failed Woodruff key allowing the pulley to spin on the shaft.
Garry
Adding
Drive belt part number and size is on this page. Just noticed they used different transmission pulleys so the belts are different for each year. That is something you don't see often. Perhaps the wrong one is on it now and too long.
KC9KAS
@dambur :WRS:
Check the belts in Garry's post.
A TORO belt is a little more expensive, but it will usually outlast the auto-parts store belts.
dambur
Is there any way this could be the idler pulley?  Thanks so much for the good suggestions!
GlenPettit
The Idler Pulley keeps tension on the belt so it does not slip, but the spring keeping the pulley in contact with the belt might have lost tension.
Increase that tension (remove 1-2 loops of the Spring to shorten/tighten it, add a second helper spring, or just replace it).
Probably ––  going up slight slopes it would slow even more, almost to a stop.
Your (1985) 208 is over 30 years old, that spring is under tension all the time when not in use, may be time to replace.
The belt could also be glazed, "smooth, hard"; which would cause it to slip, can be cleaned, as with the pulleys also.
Edited by GlenPettit
gwest_ca
That's possible. Get the belt tension off the pulley so you can spin it by hand and feel how smooth the bearings are. When these bearings fail they usually get tight first and then loose because of the stresses exerted on them. Don't end up with pinched fingers. Maybe get a 2nd person to hold the pedal down to loosen the belt.
Garry
  • Similar Content
    • ebinmaine
      By ebinmaine
      How do the gears divide out?
      Is low, crawler?
      I ask because I want to SLOW down my tractor - in reverse especially - for backing trailers... But also for crawling through the woods forward.
      So am I correct in assuming an 8 - speed in LOW  is a lot slower than a 4??
