Bowdoinham Dan
Mounting Instructions
Bowdoinham Dan
Does anyone know where I can find mounting instructions for my dozer blade?  It's on an A-frame mount, model 6-4113 7.  I have a Raider 10 tractor.
Racinbob
Here ya go:
Bowdoinham Dan
Thanks--I've seen this file.  It describes how to put the blade on the frame, but I'm looking for instructions for mounting it onto the tractor.  Does such a manual exist?
Racinbob
I see what you're saying. Use this one. Different number but that doesn't matter.
gwest_ca
Here is the other half of the 6-4113 plow package
Garry
AMC RULES
jeff lary
Dan is that Bowdoinham Maine by any chance? I have an Uncle that lives down there.
  • Similar Content
    • loudtractor
      By loudtractor
      96-42BA01 plow. Brand new in box. I assembled to make sure all parts were included. Did have to add a trip spring, spring rod, and index rod. Someone "borrowed" them as it sat in the warehouse for 50 years. Box is a bit rough, but I could reinforce it for transport. I will disassemble it, need workbench space.
      Made for (per manual):
      1974 A800,
      1975 A80
      1976-7 A90 A100
      I believe vertical shaft tractors. Maybe others?
      Thanks for looking
      Matt
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • Nuzmuz
      By Nuzmuz
      Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
