Michael J. Shaffer
Kwik-Way Loader Wear Bar / Edge
I apologize if this has already been discussed and/or answered. I searched as thorowly as possilble and found no thread on this.
I/we (apex-techs) have a Kwik-Way Loader. It is missing the wear bar / edge and we would like to obtain one, so as not to wear down the actual bucket. I cannot find a part number in any of my searches. Does anyone on "the square" know if Kwik-Way made/makes this? There are visible holes all along the leading lower edge of the bucket (much like a snow plow/dozer blade) which leads me to believe that it did come with one, when new. We will be mounting this on a 520-H. We acquired the loader with a 518-H that was "ridden hard & put away wet" and doesn't have the heavy duty front axle (hence, why we're putting on the 520-HB)). Any help will be very appreciated.
Also, any other do's don'ts tips and maintenance advise will help ;).
Thank you,
Michael
I have a Kwik-Way on a 520H.  There are no holes in mine and I guess that yours was drilled by the previous owner.  Just get a piece of steel and transfer the holes or weld the steel and eliminate the problems with bolts causing damage or hindering dumping.
One issue is that the pump is mounted on the sub frame and the belt tension varies, so be careful that you don't overload the pump but still have enough tension.  A center hitch in good condition will help.  I used the widest belt possible so the tension can be less.
Edited by lynnmor
Thanks for all the information and advise. We will make sure to check the belt tension. Great idea on the wear edge!
Best regards,
Michael.
Every loaded I've encountered has had the cutting edge welded on . It's al long tedious process of grinding off the welds then replacing it with a new one  :tools-hammerdrill: . Go to your local ag tractor dealer and they should know where to get universal replacement edge  :twocents-02cents: .
Kwik way still exists but they will be ZERO help to you.  They offer no support to loader owners unless you have the loader they currently build for the simplicity legacy tractors.  And even then they'll probably refer you to a simplicity dealer.
I know this because one year ago I did a complete resto-mod on a kwikway loader.  They are no help.
If you need a new cutting edge, just search loader cutting edge on eBay.  Tons of custom solutions there
Edited by Snowmobileaddict
Thanks for all the information. I was kind of getting that feeling, from Kwik-Way (no help at all).
Michael .....:wwp:
12 minutes ago, WHX8 said:
Michael .....:wwp:
I will make sure to post them. I promise. We're picking up our 4th 520-H today. Once we swap out the 518-H (the one the loader is currently on) for the 520-H, I will make sure to take plenty of photos.
FOURTH!!! You'd  better put the patch on your signature &   join the 520 club then!
I have to disagree. Albeit they're no longer manufacturing loaders for garden tractors they're still willing to pickup the phone and answer questions. I contacted them 2-3 years ago for a loader manual for my 522xi. They shipped one free of charge.
Tried them again last year for a new loader bucket. Said he had one left and ZERO plans to make anymore. For the price of shipping I opted to make repairs to mine.
As as for  anew cutting edge just visit
a local metal shop and have one cut.
Clearly we dealt with different folks on the phone there at different times.  The people I spoke with in December 2015 wouldn't even e-mail me a manual.  And believe me, I know how to talk on the telephone and be respectful.  Both times I called, people were very short and in a hurry.  Maybe this was after Bleu MFG took them over.  The family that started Kwikway (Don Molstad) sold to Bleu not all that long ago.  Their interests are more aligned with skid loader attachments now.
I don't know anything about the sale. We clearly had 2 completely different experiences. Did u ever get a manual?
One thing to keep in mind is, the cutting edge is only as strong as what it is mated to. The cutting edge can give a false sense of security thinking its protecting the bucket from wear. The Kwik-Way bucket is not made of a very thick steel It's very easy to crack, rip the steel a cutting edge would be bolted or welded to. Even though a protective cutting edge is warranted, care should be taken to how it's mounted.
Doc724 was super helpful and snail mailed me a manual for the kwik way loader that he owns for his 5xi.
I made a hi-red scan of it an posted it in the manuals section of this site.
Doc was also super helpful in providing numerous critical measurements that I needed in order to fabricate a sub frame for my loader to mount it to my 5Xi
Edited by Michael Shaffer
Signature didn't work
On 10/31/2016 at 9:42 AM, WHX8 said:
Michael .....:wwp:
In the first picture, apex-tech is backing up the most recent 520-H that we picked up yesterday. This included all the manuals, 48" side discharge deck, vacuum bagger, snow cab (Original Cab Company), 42" dozer/snow blade, wheel weight, show chains and some other goodies as well. We took off the roof & vinyl from the snow cab for transport.
Nice collection of 520's there!:handgestures-thumbupright: Hopefully the vac baggers work with the leaves you have there!
Michael .....:wwp:
Thanks! They work VERY well. I have 2 more photos but having issue up-loading.
Your picture upload may be limited by your membership status?
Thank you. I didn't know that. I am new to the Square. I guess I have shared all I can, for now (picture wise)
:text-yeahthat:Need to go vac the neighbor's  lawn & earn a couple of bucks for that supporter status!! Won't take long with those tractors!
Michael .....:wwp:
Here is a link to all the photos, including the new 520-H, from last night
Misspelling
  • Similar Content
    • By MalMac
      Fits long frame tractors
      Front-End Loader Manual #810092R1
      14 pages 3.5MB
      DNA
      97-40FL01 replaced by 1980-84 model 07-40FL01
      1974 model 97-40FL01
      1975 model 97-40FL01
      1976 model 97-40FL01
      1977 model 97-40FL01
      1978 model 97-40FL01
      1979 model 97-40FL01
      1979 serial numbers that have shown up for the 97-40FL01
      005022 - Build date 1978 8342 December 08 Friday
      005194 - Build date 1979 954 February 23 Friday
    • By mmmmmdonuts
      With a front end loader for these tractors how important is a ladder type subframe? Does the cross piece in the front have to connect where the towers are? Can the frame where the towers are just mount to the frame and go back to the transmission or is that cross piece critical where the towers mount? Could it be set further back with the same effect or would it not be the same? I know it is important to go back to the transmission so if you hit something you don't snap the frame, but how critical are the cross members?
    • By sportscarclinic
      A year or two back I purchased this with a Bolens 1886 and a GT10. I don't know anything about Bolens tractors, I own three Kubotas. I thought that I would modify the loader to fit a B6000 that I own, so my son would have a small tractor to 'work' with me. It's also large enough to squeeze onto my B7100, and the specs compare to the B1630. But I had second thoughts once I discovered how rare it is to find one in this condition that is purpose built to fit a Bolens.
      The loader and tractors were in a barn under cover, so apart from expected surface rust, everything was in great condition. I sold the tractors, but kept the loader. The loader is missing the four front pins and the lower mounting beam that I know of.  There might be other parts required for mounting to the Bolens and another tractor.  I'm including the manual which has good drawings and lists all the parts in case something needs to be fabricated.
      The loader is a Workhorse Model 14 (nearly the same as Model 24). The specifications are posted on the booklet photo. It has v-belt driven pump that turns and feels like it's still pulling/pushing fluid, but I haven't tested it. The hydraulic lines were full of clear fluid, and all the cylinders are fully functional and tight. I had my son work the spool valve so that I could push/pull the cylinders, and they moved with difficulty like I would expect, but smoothly without any binding.  No obvious signs of any leaks on the spool valve or at the cylinder seals, or hoses. However, I did notice one pin hole leak in one of the steel hydraulic lines on running across the support above the bucket when I worked one of the bucket cylinders. Other than that, the hoses actually look pretty good, although there are a couple of gashes in the rubber covering here and there. The pins on the lift cylinders hardly show much wear at all, and all pin bores are concentric and tight.  I think it's safe to say the loader wasn't used much. The bucket has a high carbon cutting edge that shows very little wear.  The bucket was primed when I got it, and it does have a bit of rust scale and shows pitting through the primer from where scale was removed before priming. It's still rings really solid. Spool valve operates as expected and I had to have my son operate it so I could push the cylinders in and out the take the pictures. The cylinder rods are in great shape, no evidence of rust or wear in the seal travel zone on any of them. There is some surface rust outside on the ends near the pins as shown in the pictures. The loader frame looks rusted, but this is nothing but surface rust, it's obviously made of good quality steel.
      I'd like $1500 for the loader as shown with the manual.  I have many additional photos, but the site limits the number I can post here.  I'll likely post the loader to other sites, and advertise locally as well. I should be able to ship the loader on a pallet to your locale Fastenal, for $125-200 depending on your location. Or, you are very welcome to come to Portland, OR and pick it up in person. conrad503(AT)gmail(dot)com is my email address, and that's the best way to contact me.
    • By elliot ness
      I picked this jewel up yesterday at a John Deere dealer, it's a 224 case ,but it has a 16hp Onan on it, and someone put Power steering on it. It has a few leaks, but runs great. even has a joy stick.
    • By r1jakecfd
      Didn’t get to swap the loader out for the 44” 2-stage snowblower and cab on the 520-H before the Christmas Day storm. I had the engine out to redo the top end (decarbon, clean and reseat valves, New gaskets, New fuel pump, tubing, filter, plugs and properly seat camshaft Welch plug) so no time to switch over before storm. It’s just another excuse to use the loader! Merry Christmas everyone🌲🎅🏻
