rmaynard
416-H/ARK Loader Fitment Issue
boovuc
Just seeing your build Bob. Sorry I missed it. I also have an Ark loader on a newer WH. (520-H). Mine was made for the Blackhoods as well as the older C-series and no-names so I didn't have that bracket to deal with. However, there were issues with the pump and how the Onan sits in the frame. If you look close on this old pic of mine, you'll see where I mounted my pump. Not too far from yours! Nice job!Complete_Side.JPG
rmaynard
Thanks for the picture. I tried that position for the pump, but I have one of Matt's foot pedal motion controls on mine and it conflicted. Now all I need is to design an inexpensive ballast for the back.
roadapples
Don`t want to hijack this thread, but would like to know what kind of wheels on the rear of  Boo`s 520....
rmaynard
Now that you mentioned it Jay, they are a bit different.
wallfish
Looks like two rims were used to make a wider rim for 26-12-12 tires
boovuc
Aren't they interesting! :lol:
They came on a tractor another Redsquare member bought. I bought them from him because they just couldn't be ignored! They are two rims thrown together, urr I mean welded together to hold the 26-12-12 lugs.
The extra metal in the middle is for extra traction I guess!
I have one of Matt's foot controls also but I never mounted it. I was worried it would hit the belt to the pump. Now I know it will! :)
Looks like I may be moving my pump configuration as well this winter!
rmaynard
While visiting my brother-in-law today, I mentioned that all I needed for my loader was some rear ballast. Then he said that he had something that might work. We went to his shed, moved a couple of boxes and here is what we pulled out.
Now, all I have to do is make some sort of bracket. Oh, and of course paint them red.
But best of all, they were FREE. :woohoo:
  • Like 5
CasualObserver
Can't beat that price!
dclarke
That'll make a big difference, Bob and you can't beat free.
WHX??
Really....who says BIL's are no good..... A tool box for the back to hang them on Bob extra storage for chains, straps,  pins,  clevises and whatnot. I've seen some neat pics of ones here but danged if I can find them.
Edited by WHX7
add
rmaynard
I have to make something that attaches to the frame of the loader since any bracket that would attach to the axle had be removed to attach the loader. Not a big deal. I'm still searching pictures of what others did.
Ed Kennell
Attaching the counterweights to the loader is actually the best way to do this Bob.    It takes some of the stress off the loader attachment points to the tractor.
bmsgaffer
Holy cow Bob, Free is awesome!
Those weights (even the knock offs) are approaching $1 a lb. unless you get a REAL good deal. I had to buy over 1000lbs of them to get a reasonable price.
  • Similar Content
    • edwroy
      By edwroy
      Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
      Thanks,
      Edwroy
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • chevyaddict83
      By chevyaddict83
      So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
      Sent from my LG-LS980 using Tapatalk
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
    • bo dawg
      By bo dawg
      Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
