gtofani
1967 wheel horse with tecumseh engine
gtofani
I am looking for a place to buy a carburetor rebuild kit for my 1967 wheel horse with a Tecumseh engine.
It fires right up with the instant start but is not getting fuel. I figure a carb rebuild would help.
Does anyone know a part number or place where I can locate one?
stevasaurus
I'm going to assume you have either the manual or the electric start HH60-105014B (recoil)...HH60-105013B (electric start).  Here is the manual.  It is not a great copy, but it may give you numbers.  Also, check in the "Manuals section" under engines.  Quite a few Tecumseh books in there.  Once you either let us know what you have or figure it out...you should be able to find it on E-Bay or at a small engine shop that sells Ariens snow blowers (they use Tecumseh engines and should be able to look up the parts you want.  :)
AMC RULES
Great running, brand new, knock off carbs...
can be found for less than $10, all over Ebay.
I would suggest obtaining yours from a US based supplier though.  :twocents-02cents:
gtofani
how will I know it fits my engine? or are they pretty much all the same.
stevasaurus
Why don't you tell us what tractor you actually have there??  That would help.  :)  Do you have a tag on the engine??
Edited by stevasaurus
gtofani
sorry, thought I did.
its a 1967 lawn ranger with a Tecumseh engine
stevasaurus
See...I guessed wrong.  You should have the H60...either 75118F or 75117F.  Let's see what we can find.  :)
check out this manual.
Check out the blow-up and item #290...says the carb is #631067A.  Looks like it would be for either Lawn Ranger.  I don't know if that # is a Wheel Horse or Tecumseh number though.
pfrederi
Carb kit is Tecumseh 31840.    Oregon after market. 49-840  Check that the wiremesh screen in the tank isn't clogged.
https://www.rcpw.com/search/?quest=31840
Edited by pfrederi
stevasaurus
Where have you been Paul??  Thanks  :handgestures-thumbupright:
gtofani
found it and ordered it, only 13.99 and that is including shipping. great deal. thanks all.
953 nut
Have you verified that there is a good fuel supply to the carburetor?
gtofani
yes, lots of fuel , float bowl is full.
I found one on ebay. great deal.
pfrederi
  Bush Hogging with a 72 year old tractor and 56 year old Bushog  model 600  Good seat time!!
