Macgyver 90 #1 Posted July 14, 2016 I have 2 onan engine blocks one has the newer crank case breather it is metal and goes straight up the other is plastic and on an angle. Question is how do you remove them? Also one block was a vertical shaft engine but looks identical to the horizontal block. Is there a reason it can't be used with the horizontal crank & oil pump? Share this post Link to post Share on other sites
boomers_influence 106 #2 Posted July 15, 2016 macgyver feel free to call on this 651 437 2826 M-F 10-7 S-S 12-6 cent time. thank you. boomer ( the used onan engine parts guy, also NOS and new 1 Share this post Link to post Share on other sites
