bhark24
Ignition coil number
bhark24
C160 Kohler 16 HP. Mid 70's model. I don't have model number of engine available as I'm at work. But it's the standard round coil +- posts with coil wire hole in center. Can anybody give me an aftermarket part number or the original part number and maybe I can do some cross checking. I have intermittent spark on a brand new set of points and condenser. Thank You! Bill
Image is the model number of the tractor to give you an idea of the year. Motor is original. Entire tractor is original as it was sold at our families dealership back in the day. I just acquired it last week.
Edited by bhark24
Added image
AMC RULES
New condensers don't always work...   :dunno:
wonder, did you replace the plug and wire too?
bhark24
I did test plug on another motor. It fired fine. I didn't install in head and run motor but it had spark the entire time. I did not replace plug wire. Motor did run before I washed it. Will see if plug wire will work on other engine for a test fire. Condenser and points were or are a brand new Kohler set not generics. But guess I had not thought of that possibility.
squonk
Napa IC64SB coil
953 nut
I would begin be checking the points gap again. To check a condenser just unhook it, if the problem clears then it was the condenser.
bhark24
It was def the coil. Replacedbit this am with an new original Kohler coil. A mere $103.75 for a coil. But problem solved. Thanks all.
oldredrider
Not meaning to rub anything in, but that same coil as Squonk suggested above, is $27.00 at NAPA.
squonk
I used to sell a ton of those IC64Sb's to the Menonites and Amish for their homemade power plants. If it had a motor something would get connected to it somehow. :) K-Cars, Puegot's, Renault's, it didn't matter! :banana-wrench:
Edited by squonk
  • Similar Content
    • 69-Raider-10
      By 69-Raider-10
      Afternoon all,
      Newbie here so I apologize in advance for any procedural errors. Figured this would be a good kicking off point.
      Short and sweet; I have a well maintained 69' Raider 10 with the Lauson motor (HH100). I gave her a bath/wax, topped off fluids and grease, etc, and took a ride to listen for any odd noises. Running perfectly and then just died. After some basic investigation I pulled the plug and grounded it, no spark whatsoever while turning over. It's a new plug and it worked fine so it's not the plug. Motor/starter crank like a bear, no problems there. Almost has to be a bum coil or stater? Any tips on how to narrow it down or what to look for?
      Thanks in advance for any information! Love this place so far. So much excellent information. I'm hooked!
    • mr_speegs
      By mr_speegs
      I just (almost) finished a rebuild of a K181S on my 876 Wheel-A-Matic. Everything was pretty much going to plan until I realized that I had no spark. My ignition coil seems to be heating up (I assume it's working), but my plug won't spark. My plug was good before the rebuild, but the plug wire was always loose where it went into the coil. Now the wire comes completely out of the coil housing. I cleaned off the end of the wire and the socket inside the coil as much as I could, but still no spark.
      Is there a way to repair this or do I need a whole new coil/wire set?
