drewd
recommended oil for Uni-Drive
drewd
I would like to change the oil in my transmission but have read some people using 40 weight and others 90.  What's the recommend oil for a 4 speed Uni-Drive Transmission? Thank you!
Racinbob
:WRS:
I've used Valvoline 80w90 for decades and never has an issue so I guess it must work. :)
rmaynard
Back in the mid 1960's, Wheel Horse recommended 40W oil for one model. I can't recall which one now. But as of 1998 when Toro printed the chart of recommended lubricants for all models and years from the RJ's to the late 1990's models, ALL uni-drives were recommended to use SAE 90-140 A.P.I. Service GL-5 Gear Lube. HOWEVER, that is not to say that a good 80/90W  or other similar gear oil won't work, considering that many guys are inadvertently running around with anywhere from a thimble full to over a half pint of water in the transmissions at any given time. Since 1993 I have been using Walmart's house brand in 80/90 or 90/140, whichever is on sale at the time I need it.
:WRS:
  • Like 4
Racinbob
It was in 1964 that 40W was recommended. Service bulletin #55 addresses it. The reasoning was to minimize 'gear locking conditions'. At the shifter rails continued to be modified the issue was corrected with the flats in the rails and they went back to recommending the heavier stuff. As Bob said, any good gear oil is fine. 80W90, 90W140 or.....
  • Like 4
SylvanLakeWH
:text-yeahthat:
And...:text-welcomeconfetti:
pfrederi
The owners manual for my 1967 L107 specifies 40w motor oil. That has been used in her since then... changed maybe 4 times (probably about due), still in daily use winter and summer.....No tranny issues after 49 years.
I really think this area gets to be "Over thought".  Keep the shifter boot on, don't let water get in and any of the lubricants mentioned will work just fine.
  • Like 6
roadapples
:WRS:
Racinbob
I do agree with Paul on the over thought bit. Sure enough the L-107 calls for 40w. It has a 5053 transmission. Many others have the 5053 as well including my 500 Special. The odd thing is that my manual calls for 90W. But, the 657 also has the 5053 and calls for 40W. Apparently they made the switch in 1968. :confusion-confused:
  • Like 3
drewd
Thank you all for the replies!
WHX??
Your :text-welcomeconfetti:
gregg'shorses
I think 40w engine oil and 80/90 or 90/140 gear lube are about the same viscosity.
  • Similar Content
    • jmack
      By jmack
      I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
