BigRedGrizzly
1970 GT14 Resto
BigRedGrizzly
3 hours ago, ztnoo said:
Which "belt" are you referring to???
Belt that drives the deck off the electric PTO?
Sorry for not being clear... but, yeah, I am referring to the belt from the PTO that drives the blades on the mower deck.
ztnoo
That's what I assumed you meant, but needed clarification to answer your question.
The original Wheel Horse number is 9783.
It's a 1/2" x 71" belt.
I use a Gates PowerRated belt which is 6871.
Edited by ztnoo
BigRedGrizzly
I used a Gates PowerRated belt which is 6871.
Awesome! Thank you guys👌🏻😎
BigRedGrizzly
Just ordered one up.
BigRedGrizzly
Hey all.... I just wanted to follow up with you all. I installed the "very proud" ignition and it started fine. However, the electric PTO and the lights were not working. I spent an hour trying to figure it out and gave up. From what I can tell, I think the power leaving the ammeter is compromised. So instead of messing with it too much I just bought a couple single pole toggle switches and wired them up. Now I have a toggle switch for the electric PTO and the lights. Everything is back to working. I also installed the new mower deck drive belt as suggested. I had to relocate the adjustable pully wheel to get the proper tension on the belt. All and all it functioned great. I have another deck which has a couple rust holes in it. I'm going to strip it for back up parts. Any way here are some pics and a vid....
ztnoo
Glad you got your belt and got the deck mounted and running.
Just a heads up........make sure when you do your final adjustments that everything in the mule drive is in place correctly and that that Idler pulley in the slotted hole in the cam plate is good and tight.
Does your pivot arm assembly (the elongated cast piece which holds the idler pulley) have grease zerks? Mine does and it goes a long way to lubing and adding service life to a part with lots of load and stress. Mine are drive in zerks and were on my tractor when I bought it 36 years ago. There should already be pre-drilled holes in the pivot arm for the zerks.
As to your electrical quirks, you might try giving the battery posts and cables a good cleaning  to ensure excellent mechanical contact. That positive post and cable look to be corroded somewhat.
I found once that my electric clutch wouldn't function with low voltage, which was ultimately caused by cracked and broken spades on the rectifier and the battery not sufficiently charging........just saying keeping those posts and cable clean can really help eliminate lots of quirky electrical problems.
BigRedGrizzly
Hey there ZTNOO....Thanks for the tips... I didn't notice any zerks in the area you mentioned. I did remove the eclip and lube up the shaft pretty well. I'm figuring this will be a yearly maintenance thing. Off the old deck I salvaged 3 decent blades, two spindles, and 3 pulleys. Unfortunately the middle pulley was welded to the spindle shaft. Not removable. I also salvaged the rear wheels and height adjusting mechanism.
For the bracket that attaches the mower deck someone welded washers to the outsides of the bracket. I ground them off and gave it a quick primer coat.
Here you can see some pics how I have it set up. If you notice anything out of whack let me know.
ztnoo
If your pivot arm has holes for drive in zerks, they are on the bottom of the part.
Maybe you haven't really looked at the bottom.
If you haven't looked, they may be there.......or maybe not.
See the attached pics from the pivot arm I busted about 3-4 weeks ago.
BigRedGrizzly
Hi Fellas... My 85" belt is slipping and smoking up a storm.. Lol... I'm going to be looking for a 82" or 83". I seem to have lost some power in reverse. I think it it is because of the loose belt.
gwest_ca
Transmission drive belt 8334 - (B x 84.8" or 5/8" x 84.8") - Still available from Toro
Garry
BigRedGrizzly
Hi Fellas.... I am stumped on this reverse loss of power issue I'm having. Initially I thought it was because one of my  hydraulic hoses were leaking.  So I got new hoses and I figured that would solve the problem. But it didn't. Next I thought it was because the drive belt was too loose. So I got a new nice tight belt. Unfortunately I am still experiencing  A loss of power in reverse. I am also noticing my three point harness and the mower deck slowly drops.  This happens with the motor running and of course with the motor not running.  I have recently changed the oil and change the filter but it is still happening. I am not noticing any fluid leaking anywhere. Anybody have a clue as to what might be causing this?
  • Similar Content
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
    • swisstrac
      By swisstrac
      looking for info/help re securing a front wheel bearing/race for  GT14/ 1971;  any info would be much appreciated..
    • Rob R
      By Rob R
      Sooo about three months ago I had a friend of a friend pass to me the most needy Wheel Horse GT14 Tractor I had ever seen, it was completely taken apart every single part had rust and two coats on oil paint one blue and one yellow. parts were missing and of course there was no labeling of parts or assembly there-of. All wiring, gauges, rectifiers were removed and non existent….. still the machine was calling to me to try and do the almost impossible...… My thanks to Aldon for parts and support and Kyle for Technical help and shoulder to cry on. ….  The only saving grace of the entire project is that the engine and tranny were indeed still good...… in fact the only remaining issue I have on the machine is that I cannot free-up the relief valve so that I can move the machine w/o power..... I think this might be stuck forever … but not the end of the world.
