Live4outdoors
Tecumseh carb replacements
Live4outdoors
Here we are days from big show, I've rebuilt the carb twice, had a small engine shop go over my work and I have a bad running 653,. I know everyone raves on these Chinese carbs but there are too many h60 replacements available and none look even close to mine.  I can have one by Tuesday off amazon and ready for the big show but not sure which one is right.  Thanks all.
AMC RULES
:roll:  Post up a pict of yours here.  :thanks:
Live4outdoors
All the replacements have the real high choke lever and mine is flat.  I saw your earlier post about your good luck but not sure what to use and now outta time...LOL like always
oldredrider
Just change out the choke shafts. I do it all the time and works like a charm.
Live4outdoors
Great, never dreamed they would interchange, going to order now then thank you!
wallfish
Or just simply bend that bracket holding the conduit up a little. If needed you can also bend the choke lever down a little too.
AMC RULES
:text-yeahthat:Just bent the new carbs choke lever down, where it needed to be...
to match up the angle of the original. :handgestures-thumbsup: No sweat at all.
Edited by AMC RULES
Live4outdoors
Thanks all! Got it running again, still a little temperamental but the best she's ever run, spent an hour fine tuning the best I can get it!
Retired Wrencher
Live4outdoors  Looks good glade you found one. What is the wood for rope pull start? Have fun at the big show.
Live4outdoors
I'm not sure what the wood was for maybe to stop vibration, the original owner had it in there and I just kept it.  Any ideas?
tunahead72
Try taking it off and see what happens. :)
