wheelhorseman
1533 Bearings?? No problem
41 minutes ago, Cheetah said:
Ok, I see what's meant by "pull the seals and install" now. The bearings themselves have seals in them when you purchase them, and those need to be removed before installing.
Thanks for the feedback on the description I just revised it
1533-bearing-1.jpg?1465389676 1533 Bearings
NEW reproduction #1533 Bearing - the same measurements as the originals ! Note: before installing you must remove and discard the black seals (they simply pop off) the grease will also need to be removed to allow oil to flow through the bearing and reach the outer needle bearing.
Price is per bearing
44 minutes ago, Racinbob said:
The original 1533 are closed on one side only so I'd say just do the same. :)
There were 2 bearing designs that they used over the years and the bearing pictured above  still allows some oil to get through them to lube the outer needle bearing.
  • Like 5
1 hour ago, WHX61/3 said:
Do you have a good number of them Lowell? Looking forward to seeing you at the Show!
@Racinbob has @stevasaurus seen this yet?? Funny he hasn't chimed in yet....
Yes I have lots of these on hand. I should also mention I will be doing some kind of a show special on them!
  • Like 6
"There were 2 bearing designs that they used over the years and the bearing pictured above  still allows some oil to get through them to lube the outer needle bearing."
:text-yeahthat: Closed on one side, not sealed.
7 hours ago, stevasaurus said:
OUTSTANDING LOWELL !!!!!   :handgestures-thumbupright:  :handgestures-thumbupright::handgestures-thumbupright::handgestures-thumbupright::handgestures-thumbupright:
Here is where they go...  :)  Just in time Lowell.
Thanks for posting a picture of it in its natural habitat Steve -- minus the gunk.  Lol
And I'm looking forward to meeting everyone at the Big Show!!!!!!
Question? What main bearing goes in the Sunstrand and Eaton hydrostatic transmissions? Is there also a different bearing for the 1" inch axle verses the 1 1/8" axle?
Many, many deserving Wheel Horses will be saved from the glue factory with the availability of these bearings.  :bow-blue:
Edited by r356c
sp
I have a 1974 that has needle bearings falling out the rear axle. Would yours replace them or do I need to find new needle bearings? See photo.
I live in Staunton, Virginia. I need two tractor's rear seals and bearings replaced. Anyone close by to do this?
Those are the outer axle needle bearings..  If they came out of your axle in bits like that there is a very good possibility some of the bits went inside where they can do a lot of damage.  I would pull the transmission and open it up.  lots of tutorials and help here.
manual
http://www.wheelhorseforum.com/files/file/358-transmission-gear-uni-drive-1958-1982-sm-hr-a-1392pdf/
how to videos
http://www.wheelhorseforum.com/forum/144-transmissions/
  • Like 3
  • Similar Content
    • By mkueb
      Does anybody have a good source for replacement front wheel bearings for a mid to late 1970's D160 wheel horse tractor?  There are two push in bearing units (inner and outer) per wheel.   I first attempted to replace with standard bearings but quickly found out these are not standard sizes.   It's been a while since I check and I don't completely remember,  but I think the wheelhorse bearings where something like 1/16" of an inch larger OD than a standard catalog bearing.   At the time,  I remember finding bearings but they wanted somthing like $100 for each bearing.   I was able to located two bearings and did purchase them for a reasonible price,  but am still looking for two for completing the set.   The part numbe ron the two that I was able to locate is 104396.   If anybody has any ideas,  I would appreciate.
      Thanks
      Marc
    • By Horse playing
      Hello, everyone and thank you in advance. I got bit by the bug a few months ago and bought a 1974 b 80  the rod broke, about a month after i bought it. So to keep my 4yr old mowing i picked up a c120 auto and i was going to change rear wheel seals pulled the hub to find the axle moves up and down and side to side about an 1/8"  what's involved in put in new bearing and does it need to be done now or a winter project. Thanks
               PS sorry about the grammar
    • By arminer8
      I have a snowblower that has a bad bearing inside the auger on the chain side. Took it apart, and now I can't find a bearing like the one I need! One thing I need to know is if these parts are metric or American? If it is American, it is a 3/4" inside diameter, 1 5/8" outside diameter, 7/16" width. Anybody have a place they get them? Near Rochester, MN. It is a model 53321 snowblower I think as the model # plate is really scratched up.
    • By WHX14
      Well maybe not for free but on a budget! Some of you old timers  may already know this trick.
      I wash my horses & decks alot. Almost after every mowing i wash the tops of the decks off and have underside quick wash connects installed on all of my mowers. The price I pay for all this cleanliness is usually payed back in the form of noisy deck pulleys, idlers & spindle bearings. Hence I have been known to spend a small fortune on pulleys & idlers that, for some, can be 40-to 50 bucks a wack. So after finally figuring out that these things just have common bearings in them that could be replaced if they weren't welded in tighter than a buxom beautie in a brass bra!!
      Alas no more....
      First step is wire brush the offending noise maker so you can identify where it is spot welded together. Usually a dark spot or a dimple marks the spot. Center punch the spot, notice the symetrical patern of the welds.
      Next drill out the welds starting with 1/8" bit then 1/4". proceed to 5/16' if it appears that 1/4 " did not take out 90% of the weld.
      Next position the pully on a block of wood and separate the halfs.
      Use a small cold chisel.
      It may take a bit of effort to separate them. If the half bend a little they can be hammered strait after apart.
      Remove the bearing & drive out the bushing if it has one.
    • By WHX14
      When going thru my front end I decided to replace the front wheel bearings, the real common 1 3/8" x 3/4".  After getting a set of four off ebay they came with the grease seals on both the outside and inside. Question is should I remove the seals on the backside and continue to grease thru the zerk or let them ride as sealed bearings? My inclination is to let them ride as sealed bearings.
