ishmael1980 1 #1 Posted June 3, 2016 Hello All, I am in need of a deck for my 1989 310-8 (Model 21-10K806). It had a 37" side discharge and I'd like something that size or a little larger. Can anyone tell me what decks will fit this tractor? Does it need to be a deck from a 310-8 or will other decks fit? Thank you, Bob Share this post Link to post Share on other sites
stevasaurus 22,229 #2 Posted June 3, 2016 I think any deck from 1973 "no names" and "B" and "C" series will fit. 2 Share this post Link to post Share on other sites
ishmael1980 1 #3 Posted June 3, 2016 Thank you for the quick response. Do you know if all of the 300 series decks will fit the 310-8? Share this post Link to post Share on other sites
dcrage 621 #4 Posted June 3, 2016 There are no "300" decks -- There is only Wheel Horse decks -- And as Steve said any Wheel Horse deck from 1973 forward (designed for WH Garden Tractors, i.e. horizontal shaft engines) will fit on the 310-8 -- Now you probably don't want to use the 48" deck and you for sure won't be able to use a 60" deck -- While both would fit onto your tractor, they would require more 'umph' than the 10 HP Kohler could supply reasonably 1 Share this post Link to post Share on other sites
stevasaurus 22,229 #5 Posted June 3, 2016 Hey Dave, I have a 48" side discharge mower deck on my 1972 Raider 10...and the Raider handles it just fine...even higher grass. I would not put a 60" deck on though. 2 Share this post Link to post Share on other sites
dcrage 621 #6 Posted June 3, 2016 (edited) I stand corrected -- I was wondering is someone was going reply in exactly the way that you did Steve -- In my defense I always think of the "hay field" that I mow at my Dad's place and it is all my 310-8 can handle with a 37" SD in Low range/1st gear -- But then really who is trying to mow 3 ft tall fescue bluegrass yards? Edited June 4, 2016 by dcrage 2 Share this post Link to post Share on other sites
stevasaurus 22,229 #7 Posted June 3, 2016 I sometime use the Raider over at my Mom's...it is usually 6" or so when I get to it, but it goes through it. I just have to run over the clippings a couple of times, but that is in 3rd gear. Share this post Link to post Share on other sites
carlsbarn2 7 #8 Posted July 2, 2016 Neighbor selling his Workhorse & 48" desk 400.00 Share this post Link to post Share on other sites
