Anyone ever heard of an Electro 12 with a positive ground electrical system?  Have a chance to pick up a pretty decent tractor, but the electrical system seems like a mess. The guy has it hooked up with positive ground and it won't fire when cranking.  He swears it ran like a dream a week ago, but he washed it and it hasn't run since.  Also, it has 2 key switches!  One for the coil, and one for the starter. Has anyone ever heard of such a system?  Any thoughts would be appreciated. Thanks.
Only 1 switch needed, BUT it must be the correct switch.
It should be negative ground.
Someone has really messed up that tractors wiring!
Download the wiring diagram and wire it correctly!
The starter will crank in the same direction with reversed polarity and the coil will work as it should as long as the coil + is connected to the un-grounded feed from the battery. At this point it is to be presumed that the voltage regulator is history, it is polarity sensitive. Obviously the seller has no idea what he is doing when it comes to electrical work. If he tells you every thing is great but can't prove it I would start seeking a BIG price reduction.
What kind of ignition system is on the tractor.  Depending n the year (it may have a Magneto with points or a breakerless system.  Either one can be easily fried if wired incorrectly.  Then again over the years it may have been converted to a battery points system (that would be more forgiving of fouled up wiring).  Many older farm tractors had positive ground nothing wrong with that...but i doubt the Kohler voltage regulator would deal with it .
Magneto system the plug wire just appears from under the engine shroud.
Breakerless has a triangular shaped coil mounted on the front of the shroud with a single terminal on the bottom plug wire out the top.
Battery points will have round coil and condensor.
Thanks for the feedback.  Yeah, I think they really messed with the electrical system.  It's a battery points system with an external coil.  I doubt the voltage reg is still good, but that can be easily replaced.  Any idea why they would install a second key to control the coil?
The original ignition system is a magneto which uses a different switch than a conventional battery ignition switch. The previous owner probably didn't have enough electrical know how to make the transition.
Yeah, I figured it was supposed to be a magneto ignition since my 1277 is and it's only 1 year older. Since its been converted, do you have a wiring diagram for a battery and points ignition?  In order to remove that second key, what type of ignition switch should I get?  I should probably get a new voltage regulator and coil as well.  Is there anything else I would need?  What type of coil would it be for a K301?  Thanks
This is likely the same system for battery ignition. I think your switch and this one has 4 key positions. OFF, RUN with Accessories, RUN without Accessories and START.
If you want to use a less expensive switch with 3 key positions that is possible also since you have a starter solenoid. Switch # 103990
Garry
  • Similar Content
    • By redhorserider
      1968 electro 12.  In really good condition. No rust. I've owned it for 2 years now. Starts runs mows plows. I use her all year long no problems.  48"deck 48"plow with tire chains.  All hydraulic hoses replaced last year. Wiper seal replaced in hydraulic 2way valve for up down. Fixed the leaky triangular seal on the trans already. Posi traction. New deck belt this year. New battery this year. From what i can tell most of the parts are there other than the obvious missing headlight lens and hood ornament. Well and the red paint  I replaced one pulley on the belt tensioner. Has a small oil leak. Could use new tires but never bothered me.  Could use a little tlc and i just don't have the time anymore with a new baby at home. I also know there's someone on here with a lot more knowledge and know how that can take care of her and appreciate her more then i ever could. (The tractor not the baby lol)  I got the price from people on here so that's a starting point only. I am definitely open to offers so don't hesitate to ask. Worse case scenario im gonna keep her as my plow horse and go buy a new cutter so i don't have to keep switching the 2. Heavier duty and hydraulic lift really making plowing fun.
    • By Furious
      Does anyone have a part number or know where I can get a voltage regulator for a '68 Electro 12?  I'm picking the tractor up this weekend for $250 with a working mower deck, but someone has really messed with the wiring and there's no spark.?  The ignition is a Battery points setup, currently set up to positive ground.  I'm guessing that the VR is only PART of the problem, but I want to get it back to a normal setup.  Also looking to buy a new ignition switch.  Thanks.
    • By Furious
      First Wheel Horse...a 1277. Picked it up for $400 with the plow. The guy couldn't get it to keep running after squirting starting fluid in the carb. Took her home, cleaned the carb, took the flywheel off and cleaned the magneto, put in a new set of points and she runs like a dream.  Now I have a dilemma though. I can pick up an Electro 12 for $350, but the engine isn't running and the electrical system has been completely messed up. The tractor itself is in good shape and comes with a deck. Seem like a good price?  Any thoughts? I can only keep one, so if I get the electro, I'll build one good tractor out of two. Here's some pics of the 1277.
