Similar Content
By BrianStasC-101
Hello all. I am looking for suggestions on adapting the pto from my C series tractor to a harbor freight predator 420 13hp engine. I know the predator motors are a controversial topic however it is the route I have chosen for this particular machine. The intent was to mostly use it for plowing so no PTO required but it would be handy to have. Looking to hear from someone that has successfully done the swap that may offer any advice before I attempt to transfer it over. Just looking for any general pointers that will help me along the way to make it go as smoothly as possible.
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
By t_furl43
1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well, it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4 -
By RJ Hamner
Will the plow I am using on my C121 and C160 work on a 876?
or is the plow frame different?
Thanks
Bob
By Ctlucas93
I just bought a used C-165 01-16KE01-17658. Its is odd because the rear says Toro but I don't think they bought them until '86, and the hood decals say C-145 but the serial points to a C-165, no identification on the engine at all. I'd like to find a service manual for the tractor itself and maybe a parts manual, I have a Kohler manual. It has quite a few issues but going to start working on it in my spare time. It runs very well and idles smooth. Hydro pulls good and deck lift works. I have no idea where the choke cable is supposed to mount on it. Hydro fluid is milky so i have a few filters ordered to change it a few times I just am not sure what to put in it. It also isn't charging the battery but going to Ohm out the stator per the manual, but does anyone know how to test the regulator? Also, I need to deal with the rust in the battery box area.
