Horse Fanatic
50" grader blade question
Horse Fanatic
How long is the lift bar for the 50" grader blade. I found one but it's lacking that part, I'll probably have to make a replacement.
Thanks,
Glenn
C-Series14
Well, I was hoping someone would of answered ya by now so I threw on the boots and headed out to the freezing barn :hide: and measured mine. It is 24" long, has a small bend forward at the bottom of the handle. Probably about 5" from the bottom, didn't measure that.
awd
Thanks,
Glenn
You can order the part if you need it.
I can email you the parts list for the 79356 50" grader blade if you need it.
Horse Fanatic
Thanks for the responses and to C-series for braving the cold. I wasn't aware it's still available, I'll have to try that first.
Thanks,
Glenn
Horse Fanatic
Mine is a 97 blade, a 79351. Are you aware if the lift bar #92-0983 is still available?
Duff
Yes it is. Jack's Small Engines has them for $35.25. A little pricey, but still around to be had!
Duff :hide:
Horse Fanatic
Oh, and to clarify what measurement I need, it's the bar that connects the blade to the bellcrank.
Thanks, Glenn
C-Series14
Ok, I was wrong, I measured the angle lever!!! :hide: You want the link that lifts the blade....
C-Series14
Well, I went back out in that horribly cold pole barn :D and measured the lift link....it is 12.5" overall and pin center to pin center is 11.5". Seriously, it is awesome outside, I work outside on airplanes!!! :hide:
Horse Fanatic
Thanks Mike!
