HorseFixer
Started Working In The Horse Stable!
HorseFixer
Started working in the Horse Stable today! If the truth be known instead of screwing off all summer playing with the new toy "The Motor Home" better known as the "Dukes Stabin Cabin" :wicked: and spending all of the weekends camping, I should have been working on what I'm doing now! :banghead: Well the first order of buisness is the wireing. Will be installing outlets at each tractor location as to allow for "SMART CHARGERS" ie: battery tenders for the tractors.
After the wireing is complete will be insulating and sheeting the stable with OSB.
then will paint.
Ever have problem with loose outlet boxes and outlets? Cut material the thickness to fill the gap behind the outlet box then run screws through the back of the box through the spacer material and into wall board "Make sure your screw depth is correct" If the wall board is sheetrock Use adhesive on the back of the outlet box and filler material it will make your boxes ROCK SOLID also run a screw thru the side of the box into the stud! :thumbs2:
Had to get some heat out into the stable, used a Box Fan to blow heat from the garage through a window. Once it is insulated will cut out the doorway where the window is! :eusa-whistle:
Also installed some proper vents from soffits into existing garage.
Sparky
Its looking good Duke. Nice to see the sign ya won at the show hangin up all proud like :hide: .
Mike.........
HorseFixer
Its looking good Duke. Nice to see the sign ya won at the show hangin up all proud like :D .
Mike.........
Thanks Mike I waited all day for ya to show up and give me a hand on the wireing :hide: "Us H-Vac guys only like working on low voltage" :hide: I plan on makeing a frame for the sign like Dale did on his I will Install some florecents behind it to illuminate.
stevebo
Duke,
I like it !!! Looks like you are doing it right. Good luck with finishing your stable. I think I need to expand as well. Just picked up a C175 on Monday and a 520 tonight. Why do we do this?? :banana:
kj4kicks
Looking good Duke !
Some of that is still fresh in my memory!
KyBlue
Looking good!! Diggin that sign too..
TJ
Nice job on the electrical. The only time you notice an electrical outlet is when you can't find one. :hide:
Rollerman
Looking great Duke....you really get going on something when you start?
You must have been one serious uh...er ..camper. :hide:
May have to pass through this week & give the garage the inspection. :D
HorseFixer
Thanks guys :hide: along the left side next to the garage will be a 5' 6" platform 15' long that will store (6) round hoods overhead. underneath that platform will be stored (6) more round hoods. Along the right side can store (4) more for a total of (16) Overhead on high and low areas will be large shelfs to store decks some short Implements and parts. When your working with limited space you need to give alot of forethought and planning to optimize storage restraints.
Tickster come on up! :D Eldon I know what ya mean! I cant get it out of my memory.... 1200 sq ft Garage in 1990, 1400 sq ft house addition in 1999, Kitchen remodel in 2006, 400 sq ft Stable build in 2007, Build & Move MJ's Laundry room upstairs out of basement in winter 2007, Tree removal RV & Driveway pour Summer 2008, Now the garage clean up and stable finish winter of 2008. Seems like every couple years all I'm doing is building or rebuilding something around here! :omg:
Next all those tractor restores! :omg: It just never stops! :D:hide: will have more pics this evening!
sorekiwi
Tickster come on up! :party: Eldon I know what ya mean! I cant get it out of my memory.... 1200 sq ft Garage in 1990, 1400 sq ft house addition in 1999, Kitchen remodel in 2006, 400 sq ft Stable build in 2007, Build & Move MJ's Laundry room upstairs out of basement in winter 2007, Tree removal RV & Driveway pour Summer 2008, Now the garage clean up and stable finish winter of 2008. Seems like every couple years all I'm doing is building or rebuilding something around here! :D
Next all those tractor restores! :party: It just never stops! :D:omg: will have more pics this evening!
Too many projects, too little time, Duke. Why dontcha just send a few of those roundhoods down to me... :hide:
Looking good! :omg:
HorseFixer
Well today went pretty smooth was able to get about 3/4 of the insulation up! :hide: Here are some pics.
KyBlue
Thats ALOT of progresss... Somebody was Humpin today ...
HorseFixer
Thanks scott, got off work tonight and finished pretty much all the insulating except for one wall pocket on each end. "have some wireing to complete" and will most likely do that tomarrow night. I have the the overhead lighting circuit and wall outlet circuit to pull to the main breaker panel in the garage. After that is done prolly in the next couple days will cut out the doorway into the garage. Anyways here are some pics also included some on outdoor temp and indoor temp! :hide:
Taken outside at 9:00 p.m. with thermometer probe on stable gutter.
Inside warm as toast!
Suburban 550
Lookin good Duke. :hide: I know how it is to be camping every weekend nothin gets done at home. :D
HorseFixer
:hide: Thanks Ray, Okay last night I ran some HOME RUNS to the fuse panel and tonight I started cutting in the doorway leading from the garage into the stable. This makes things much easier now that the stable is insulated and having the doorway cause I don't have to walk all the way around from the stable to the garage service door to get materials and so forth. I didn't get the doorway completed because I need to build a header and install Jack Studs on each side of the doorway to support the wall studs I am taking out that you see in the middle there. Looks like the doorway opening is going to end up at 41" I was hoping for a bit more but my biggest tractor the 1054 looks to be 37 1/2 wide on the rears less the deck! <_< on the doorway finishing Ill prolly do that tomorrow night. Here are some pics!
Rollerman
Looking great Duke.
We'll be up that way soon to see it first hand. :hide:
big mike
Stephen,stop in on the way through and you can play with the newest addition to the shop......a Bridgeport :banana:
HorseFixer
Looking great Duke.
We'll be up that way soon to see it first hand. :omg:
Look fwd to it Stephen I will be off Christmas Day on till the 5th of Jan should be able to get alot done!
Didn't get anything done tonight :hide: worked on the daughters furnace after work and then under the kitchen sink! She hired a plumber her in town and he cut a tailpiece to short and it leaked! <_< well I cant say she paid for it Cause MJ did :D She had called him three days in a row and he wouldn't even come out! She had dishes pileing up for three days! looks like a fileing in small claims court is in order! :omg:
BIG MIKE.... is this the BIG MIKE of Cub Cadet's? in Niles???? :hide:
HorseFixer
Finished The Doorway from garage to stable today! Here It Is!
bitten
Duke everything is looking good except for that shirt you have on, that should be in the rag pile :hide:
P.J.
KyBlue
Duke...there is this scary lookin feller in your picture... Must be a ghost..or a stalker..
Duff
As long as it's not a RUSTLER!!!!! :hide::D
Duff :hide:
Suburban 550
Duke, looks like you're really a busy man. When do you ever find the time to work on your horses ? The 701 will never be ready for the show. :hide:
HorseFixer
Ray the Horse Fixin will be the fun part once the chores are done! Expect lots of Horse Fixin to be going on once my chores are done. :D It will be easy once things are stored stowed and in their proper place! I can have that 701 done in two months tops ya gotta realize something Once I get on a roll I roll I'm like a pit bull I chew and wont let go till the job is done! <_< I think this is week 6 or something I went back and check the Ole posts and the first one I made on garage clean up and so forth was Nov 6th :omg: Ive been at it every day after work and on the weekends straight (only a couple days off) but have done something evey night even on the days off.
You would be well advised not to bet against the Ole Duke cause you will loose! :hide: I'm not as good as I once was, but I'm good once than I ever was. :D
gotta go and get back in the stable got lots of work to do! :omg:
Rollerman
Duke looking at that pic....can't help notice the level bubble is on the black line. :hide:
Seriously...looks good though. :D
  • Similar Content
    • Travas
      By Travas
      Hello everone reading this. Im currently in the process of building a race mower out of a front engine 8-32 toro. It was sitting outside for the longest time because of a broken axle. It believe it has a vertiical 8 hp b&s that had running. Here is some some photos of it.  I put a bifferent transaxle in because it was spare one laying around. I put it on and it fits pretty well. Altho i had to remove all the clutch and shifter parts to get it in, but hey it works. I got a wheel on and tried getting the other off the axle it was on. So i put it in the press and tried for about a half hour before in popped loose. After that it took me about 15 mins and got it off. It was really  rusted on there! Put it on the transaxle to how it fits and looks. Now im in the process of drilling a hole the axle for the key in the wheels. Any suggestions or ideas? I will update this project when do some more work on it.
    • mmmmmdonuts
      By mmmmmdonuts
      I have approximately an 10x12 lean to shed attached to my house on the side of my side loading garage. I currently have a double door that is 6' wide by 6x10" high. The problem I am having is the door starting to fall apart. It is also framed very heavily with 2x6s. So I am currently looking to either do another double door or a garage door. Part of the reason the door is getting damaged in the first place is because water pools at the bottom of the door in the winter and freezes and I have to basically heat and or chisel the ice away. It is where I store my snowblower.
      My wife ruled out a sliding barn door and a roll up door mainly for appearance purposes.
      I was starting to lean to a 8w x7h regular garage door but see a few cons.
      1) It would block the light when up.
      2) I would lose quite of bit overhead storage and about 2 feet of wall space.
      3) There would be much more work reframing parts of the wall to fit the door.
      Pros.
      1) I could fit my wheel horse plow and snowblower side by side.
      2) Shouldn't freeze to the concrete as easily with a rubber seal.
      3) Don't have to shovel out the doors to get the snowblower out.
      I was wondering what thoughts you guys had on and if I am missing something.
      Thanks.
    • CasualObserver
      By CasualObserver
      I've been dreaming of a new shop space to work on tractors and generally store things at my house. We already had a three car garage on the house and could only fit one vehicle in it due to the large space that kids toys, bikes, zero turn mower, shelving and a workbench already occupied. Well.. that stuff and a few or so little garden tractors... but they don't take up that much space, right?   Anyway...  we'd been talking about building my dream shop for several years. We live on a large in-town parcel, so there's plenty of room, but as with most things, it comes down to when it can fit in the budget. I drew it up several times on the building designer at Menards dreaming of when we could go forward. Well, in the early 2017 we decided to go ahead with it, and I came up with my final layout plan.
      We proceeded under the option of build the shell, and finish what we can later. We went over and over the list of things to do now and later. Things I wanted that had to be done now for sure were the rough in for the in-floor heat and the attic trusses. I had a contractor friend who would GC and frame it for me if I bought all the materials and he could do it on his own schedule. Yep, done. I figure I could have built it myself, but it would have taken most of the summer of every night and weekend, as well as the headaches of arranging the subs for the stuff I couldn't do, but if he could do it, and he has all the contacts/subs already... I'm money and time ahead to work some extra overtime and avoid the headaches.
      The previous owners of our place had a gravel RV parking next to the house. The old poorly done timber walls were deteriorating and leaning with age.It was convenient for parking the trailer, and nice when the kids were little that we could park off the driveway so they could play, but every year inevitably it was always a weedy mess by mid-summer.
      Step one, remove ugly timber wall.  Lucky for me my neighbor had an chainsaw with a garbage blade on it. He came over and we were able to cut the wall into 12 ft sections that we loaded on the trailer for the dump.
      Next, met with our contractor friend to stake and mark it out. Since part of the goal was to reduce the amount of gravel, the equivalence of one car parking space was being removed and returned to grass on the left edge.
      Then just before the excavator was to start work, the kids and I did a little groundbreaking for the big project.
      Some gravel removed and sand base laid down and compacted.
      Concrete guys laid the forms for me on a Friday night so I could lay the insulation and pex for the in-floor heat.
       Like any kids, the call of the sand pile was irresistible.
      Next day I had help to lay the insulation boards and pex. Might seem silly to see two people carrying these boards that weigh all of 2 lbs each... but notice all the pavers? I'd been hoping for good weather to do the insulation and pex..... what I got was great temperature, bright, sunny......and 25 mph sustained winds with 40-50 mph gusts. So.... two guys to carry each flippin' board and weight it down. Ugh.... made the process much longer.
      Got the pex down, which went very smoothly. Three zones, stapled to the foam board.
      Monday morning I get a call.... inspector won't pass it because there's no pressure test on the pex. Ugh. Nothing about that in our building code, but what am I going to do? Project can't go on without his initials. So... I build a pressure manifold, tie all three zones into one long line and charge it up.  Tues morning, concrete guys are onsite... inspector shows up and says ok.
      By the time I get home from work, I have a new slab.
      Lumber pack shows up the day before the family and I are leaving for a week at the cabin. When I pulled out of driveway, construction was underway. We got a few progress pics through the weeks from various friends.
      And I returned a week later to this.  Totally the best way to build a shop!  I was out of his way, he was out of mine... worked out perfectly.
      I installed the overhead doors, had the electrician come and trench the electric over. Got the gas line roughed in for the boiler as well while the trench was open.
      After that, the excavator came back with the final top dress for final grading.
      We bit the bullet and decided to go with sod right away. Even got the kids to help for a little while. Couple of neighbors (one of whom happens to be a professional landscaper) came over the chip in too, and three pallets later....
      Now we're at slow progress time. I bought all the construction materials on a Menards 11% rebate, so once I got the rebate check I started to finish the interior. Got the vapor barrier up, and ceiling rocked with 12 foot 5/8" type x. 105 lbs each. Ugh. Thank God for drywall lifts, right!?
      More rebate checks allowed for the insulation and rock for the walls.
      Then we came to a complete standstill..... got enough stuff moved out of the house garage to get both the car and truck in for the winter, but with no heat and no ceiling insulation the shop was just a big storage box for winter.
      Spring this year rolled around and prioritizing shop work made it to the list. I realized it's going to be much easier to get the interior done before I move in. So... started back at it. I got the floors masked off and got tape and mud done... then the girls helped me paint.
      Did the floor with Rock Solid polycuramine kits from Menards... grey with flakes and a textured topcoat to make it less slippery if wet. This is a long and multi-stage process. First it required renting a diamond grinder and grinding off the curing sealer. Then powerwashing three times to remove all dust and debris.  The base coat went on, cured for a few days, and topcoated three days later. Then I let that cure for a week before moving in. It's supposed to be cured in 24 hours, but why rush it if not necessary?
      Finally ready to move in.
      Got some used kitchen cabinet take outs and installed them for the workshop area.
      Really looking forward to getting stuff organized and cleaned up now.  It's totally a dream come true. Still have to buy and install the boiler and get the ceiling insulated... but those are things that can be worked around. Up until this point it's been much easier to have minimal stuff in the way.
      If you made it all the way to the bottom, thanks for taking the time to read it.  Get more done, have more fun!!
    • Pullstart
      By Pullstart
      Pretty soon, the tractors will have a place for everything and everything in it’s place!
      We put up another section of racking and it will allow for some custom pallets at 66” long and 44” wide to store tractors 3-wide in the racking.  The closest green upright is 9’ tall, it’ll be a shell for the buggy to rest on top of
