JAGS
1961 551
russellmc301
NICE LOOKING tractor.
saving them from the grave yard is the best
WHX??
Looks to be a 501 Suburban and looking real good. How do you bend a flywheel like that?
:WRS:
wallfish
NICE
Think 61/3 meant a 551 suburban. Also curious how the flywheel got bent
JAGS
Apparently one of my nephews was going to rebuild engine in shop class and couldn't get the flywheel off, has pry bar marks all over it.
WHX??
Yes my bad
wallfish
That sucks!
BTW :WRS:
Is that the original H55?
Edited by wallfish
russellmc301
do you still have the b-145?
JAGS
Thanks for the comments. Did the 501 also have the h55d motor? Curious, was under the impression it was a 551.
I think its original, My dad got it in about 1973 and its the same motor that was in it. As for the b-145, it was scrapped about 25 years ago. Always loved that electric mower.
Racinbob
Nice tractor. There was no 501. They had a 401 with a Kohler. :)
Yours is definitely a 551.
AMC RULES
You're doing some nice :wh: work there.
            :WRS:
Shynon
Nice horse, :text-welcomeconfetti:from a fellow Minnesotan, your not too far down the road. I think I have flywheel for a 5.5 Lauson
  • Like 5
wallfish
Probably is, an H55D is the correct engine for your tractor. Can't remember the exact spec# but thinking it's like 233? something. I'm sure someone will post it or I can find it if you want it.
Man, that little motor did A LOT of work if it turned over 3 acres every year, plus did the mowing too!
BOOOOOM, Shynon just hooked you up! That's what this place is all about!
  • Like 5
JAGS
Thank you, Isn't this snow just fabulous. Would you be willing to sell that flywheel?
JAGS
yeah it's a H55D, went through it and the governor was laying in the bottom. Bought a h60 off a snowblower for the camshaft and governor. Just have to get a flywheel, figure out how to route the choke and throttle cables and where selenoid was bolted. Sucks when you tear something apart and don't get back to it for 3 years.
Retired Sparky
 Hello and :text-welcomeconfetti:  TO :rs:.
Shynon
I have one for a pullstart. I think you could take the ring gear off and put it on this one
  • Like 4
KC9KAS
@JAGS :WRS:
Very nice looking Wheel Horse, and thanks for a little history of it.
The engine (original) was H55D-2113 according to my spreadsheet....but it was wrong once this week!
Edited by KC9KAS
Phil854
Great start on your restoration!!!
SylvanLakeWH
Nice Job!
JAGS
Edited by JAGS
953 nut
:WRS:  This manual may help answer some of your questions.
WHX??
You the man now Tom ....
Shoo some more of them moose across my driveway
Pullstart
Wow what a great looking tractor, great work!  It looks to be in great condition for the amount of work it was given, unless you've done major surgery on the sheet metal in those 3 years...  Welcome to the forum, this is surely the place to be when it comes to :wh: on the web!  We just missed the snow by about an hour's worth of driving over here.
russellmc301
looks fresh out a crate:)
the forum is full of a bunch of wheel horse geniuses that will help with any question and will tell you how to do it.:techie-eureka:
