arminer8
Lift Assist Spring
arminer8
I saw a post on here earlier of a lift assist spring. What exactly does this do? Can I get a dummy crash course on this? Also, does anybody know how to make a homemade one for my snowblower?
Edited by arminer8
rjg854
It helps to lift a snowblower
JAinVA
The lift assist spring is used to help raise the snowblower or tiller.The attachment is raised manually and at this point the spring is tensioned by tightening an attaching eye bolt.When the implement is lowered the spring is stretched and helps when the implement is raised again.This is very helpful on manual lift machines and when used on hydro lift machines reduces loads on the blower lift flag and lift cables on tillers.Luck,JAinVA
Ed Kennell
I make mine from old garage door springs.    When I had my blower on a manual lift, I had 3 springs and by adjusting the tension with  a turnbuckle, I could float the blower with no force on the lift lever.     I latched a piece of round bar in the center attach-a-matic for an anchor point and welded a bar to a spacer between the flag and push bar for the other end of the springs.
I have pictures some where.   If you search "lift assist springs" you may find them.
Ed Kennell
wrightorchid
Any way to do this for the mower deck?  I do have an electric lift that I need to mount, but have to resolve the rest of the electrical issues first.  I have a 312-8 and a 42" SD deck.
Ed Kennell
Probably would require extending the vertical lift bar (the one used with the flag for blower lift) down several inches and attaching springs from there to the foot support rod.
It would have to be the correct height to clear the mower deck carriage.
Ed Kennell
IMG_1876 (640x480)    Sorry, image won't open.
Edited by ekennell
can whlvr
I don't think it would very well for a mower,you don't want it to spring up when hitting bumps,the decks arnt that hard to lift so a smaller spring would be needed
Tankman
Years ago, from a salvage yard, picked up Caddy hood springs. Worked great.
The Caddy hood springs are doubled, a spring inside a spring. Length was good too.
The spring-in-a-spring had a lot of ummpth!
I guessing the aircraft carrier (size)  Caddy hoods were very heavy.  :rolleyes:
  • Similar Content
    • neilevans1971
      By neilevans1971
      42in Snowthrower #79362 for sale
      You pick up, as I cannot deliver.
      Lot's of fun to clear a sidewalk in one pass or driveway in just a few.
      I have the manual, belt and attachment parts that go with it but are not pictured. All are in good working order.
    • BrianKoch
      By BrianKoch
      Gentleman, I’m in need of:
      Mower deck rod lift part # 6699
      (I really just need the rod, not the trunnion or nut)
      Thank you!
    • KC9KAS
      By KC9KAS
      My 875 is missing the small spring that is attached to the cam/neutral plate.
      The part number is 1230 and NLA.
      Anyone have one or know the dimensions of the spring?
      Thank you!
    • bizzo15
      By bizzo15
      So long story short I scored a two stage snowthrower for my 520xi in the off season and hooked it up to my tractor and finally got a chance to use it this past weekend after we got a storm that dumped about a foot of fresh now.  First time out everything was going good and the snowthrower was moving snow like a beast, I did notice though when I got to the berm at the end of the road the blower would shake and vibrate pretty good when going through it.  I thought it was just normal operation since the snow tends to be more compacted from the plow, I just made sure to go nice and slow when I got to the end of the driveway and was able to clear my driveway and the neighbors without any issues.  Fast forward to the next day and I fired up the tractor to clean up the driveways as we got another couple inches over night.  Was able to finish my driveway but halfway through the neighbors when clearing the end of the driveway the blower shook and the suddenly stopped.  I shut it down and looked around and noticed the belt was broken, I didn't think too much of it as when I put the blower on the tractor the belt was showing some wear but when I saw how expensive the toro belts are I decided to run it as it looked like it would make it through another season no problem.  Once I got it back in the garage I removed the belt and that's when I noticed that something didn't seem right, the spring loaded pulleys on the right side of the pulley box were hanging below the blower frame, I took the chain and belt cover off the blower and noticed there's damage to the main belt pulley on the blower as well.  I pulled the pulley box off and noticed that there's groves worn into the metal from the pulley and what looks like some belt rub.  Anybody have any clues on what caused the belt to fail?  I'm including pictures to hopefully give some clues to those who have used these blowers extensively.  I followed the manual while installing the blower but I'm wondering if maybe I don't have something assembled correctly or am missing some crucial part.  I'd really hate to spend the money on a new belt only to have it blow because I didn't correct the actual issue.  I will say all the bearings seem tight on the blower and there doesn't appear to be any play in the shafts.  I look forward to any insight you guys can offer, thanks.
    • 608KEB
      By 608KEB
      The tall chute snowthrower on my 520H  will twist the kotter pin and disconnect from the lift rod.  I've  also used  kotter keys with worse results. Has this happened to anyone else? I do have 2 washers on the end of the lift rod. Adding maybe 1/8 of a inch to the total length  of the lift rod.  I've  never had a problem  with the short chute snowthrower  that I have hooked up to my B100.
