Wheelhorse Fanatic
Antifreeze in tires?
Wheelhorse Fanatic
I recently thought of the idea of filling my tires for my 312 with biodegradable antifreeze but then wondered if it will help the tire to dry rot? Has anyone tried this before or have any input:eusa-think: my other option is to put in tubes and fill them instead to kinda make like a water jacket thing.
ri702bill
Hello, welcome to the Forum.
I filled all 4 of mine on my 854 with winter windshield fluid.. They already had tubes in them to begin with, so the corrosion of the rim and the tire dry rot were not problems. Well worth doing if you are going to plow snow - the rears used 4.5 gallons each, the fronts about 1 and a quarter gallons. Greatly improved traction and steering.
Bill
Coadster32
I have doen this in the past sucessfully as well. Make sure the keys in your axle are good, as this does add stress to them. Also, they might tend to flat spot if your tractor sits for a time. Good luck.
boovuc
The flat spot is very true. I filled all four of my tires years ago on my C175 when I mowed a slate soil hillside. It's all I used it for so the next spring when it was time to start mowing, I had a BAD case of the thumps! If you would use your tractor year round, no issues doing them in Windshield Washer Antifreeze. (Biodegradable coolant is very slimy and will remove the paint from your rims if your tube starts leaking).
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Need a pair or rear rims for 518xi, 520Lxi, 522xi, 523dxi, GT18, GT20, GT22, GTD23D, tractors.  Can take new old stock, nice used, or used that need refurbishing.  Anything will be fine.  Needs to be within 2 hrs of Erie, PA, or shipping available.
      Thank you,
      Mike.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
