historian1895
C-145 compatible Snow Thrower questions
historian1895
I have a great C-145H. I am seeking a WH snowthrower.
A) Interchangibility list says a 06-42ST02 will work. What other WH snowblower will interchange with my machine.
:hide: I have a 06-0100 6 snowthrower. Can it be adapted to fit my C-145? Thanks so much,
Ross
C-Series14
The C-145 Auto as it is called is a nice tractor. Now, there is no VIN number 06-0100 6 thrower. Coluld it be a 6-0200? If it starts with "06" those are 80's model snow throwers and blades but it should look like the number you gave from the interchange list. What is the size of the thrower you have and what are some characteristics to help us id it?
historian1895
Mike,
Just checked again. My snowthrower is a 6 0100 6. Can it be adjusted to fit my C-145 Auto?
C-Series14
Well, according to all my books, all my websites, and the Toro website, there is no such 6 0100 6. WH used dashes in between the numbers and like I said earlier, there is a 6-0200 which is a 1972-1973 32" snow thrower. Description would REALLY help! We will figure this out...
Try Toro yourself, it has alot of info...
http://www.toro.com/home/index.html
Find the Customer Care section and go to town!
historian1895
My 6 0100 6 Wheel Horse snowthrower
I am including a link to photos of my snowthrower.
Thanks SO much for your assistance on this matter. Thrower seems to almost hook up to my C145 Auto but not quite.
Ross
C-Series14
OK, I see the 6-0100 in the pics but it is not coming up anywhere! I need the width of the thrower from wing tip to wing tip. That is where you start searching...
Does the rear bar on the thrower fit into the tractors front tach-a-matic? That is how it is suppose to mount. Lift flag goes in lower lift arm on tractor, top hole.
OK, I found 6-0100 on the interchangeability chart!!! It is a 1971 32" thrower which had the original VIN or model number some call it superseded to 6-0200 which was a 1972 model.
http://www.smallenginepartswarehouse.com/parts.asp
If you go there, click on parts lookup, use Toro Wheel Horse Consumer, it is a whole new world of info...
CasualObserver
the 6-0100 is a 1971 32 inch snow thrower. It's on the attachment interchange 1971 page (5th one down) I'm attaching the page.
It fits
800 Special
800 Auto
Workhorse 800
Raider 10
Raider 12
Charger 12
Bronco 14
Attached File ( Number of downloads: 77 )
Pages_from_Attachment_Interchange_List_1955_2000.pdf
C-Series14
Thanks Jason...Once I saw it on a real tag, I knew it was somewhere!!!
CasualObserver
You just beat me to it Mike... got a phone call while typing. I already had the page split out and everything so I went ahead and posted it. :hide:
