Jerzguy2 23 #1 Posted November 8, 2015 (edited) Just wondering what the cost is for replacement deck spindles and are they readily available? Also, can the bearings be replaced or do you just replace the whole spindle? Thanks, Jack Edited November 8, 2015 by Jerzguy2 Share this post Link to post Share on other sites
SALTYWRIGHT 859 #2 Posted November 8, 2015 JUST REPLACE THE BEARINGS. Share this post Link to post Share on other sites
doc724 924 #3 Posted November 9, 2015 Use high quality sealed bearings (sealed on both sides) and remove the grease zerk fitting (replace it with a 1/4-28 set screw). Most of the single sided bearings get the grease seal blown anyway because owners pump in too much grease. I do the same for my front wheel bearings also. Less mess on your tractor too! 2 Share this post Link to post Share on other sites
Jerzguy2 23 #4 Posted November 9, 2015 Thanks, new to rebuilding and wanted to get an idea of what it cost to put a marginal deck back into good working condition. Jack Share this post Link to post Share on other sites
