Aussie
C125 - 36" deck model # ?
Aussie
I picked up a very tidy 1983 C125 this week. It is a well travelled tractor having been sold new in the UK and then imported into Australia about seven years ago. It is fitted with a 36" rear discharge deck. The tractor model number is 11-12K801. The ID plate on the deck has lost its clear cover film and consequently the number is gone. Is any-one able to let me know the likely model number? I need an outer pulley which are a smaller diameter than my 42" decks.
thank you
gwest_ca
Is there a part number on the belt routing decal? That may narrow down the possibilities. The left and right spindles already look different so worked on before? With a mylar cover on the decal I suspect the deck is a later model than the tractor.
This chart may help to identify
http://www.wheelhorseforum.com/files/file/671-chart-spindle-id-mower-rotary-1969-1989-35-pagespdf/
The last design used a standard nut and lockwasher to mount the pulley and the Woodruff key was eliminated.
This could also be used on older spindles that used a locking nut and Woodruff key as long as the pulley was free to spin on the shaft without the nut being tight. The direction of rotation kept the nut tight. If it has been changed you will find the slot in the shaft and pulley for a key but no Woodruff key installed.
Garry
gwest_ca
Here are the deck models. Each line has it's own parts list
1983-1984 model 05-36MR02
1985 model 05-36MR03
1986-1990 model 05-36MR04
1991-1992 model 05-36MR05
1993 model 78305
1994 model 78305
1995-1999 model 78305
2000-2006 model 78305
Garry
Adding - The 106748 deck decal for belt routing was used on all of them according to the parts lists so that won't help.
Edited by gwest_ca
Aussie
Thanks for the quick replies and the information Garry.
The deck has been bodgie repaired in the past and the left pulley is an aftermarket aluminium one held on by a grubscrew. I haven't had a chance to pull the spindles down yet but the po told me he made a couple of spindle shafts up (the centre one is an allen head bolt).
I don't think I will have a problem with the spindles and housings, it is mainly the missing pulley as they are quite small and the part numbers don't give the diameter. I will look through the parts lists you have provided and see if the pulleys are common.
I don't know for sure that the decal would have had a clear cover, just assumed. Come to think of it the tractor doesn't have one either.
regards
Kym
Tuneup
Beautiful find. I took a look at my scrappy 125 and its 42" deck and it spans the same distance out from the wheels - leads me to believe it's a 42" but rulers are proof. It would surprise me if the spindles and pulleys are any different than those on the 42".
slammer302
I agree it looks like a 42RD with the reinforced stamping in the shell 42RMR01
Aussie
Thank you gentlemen, you are absolutely correct. I don't know why I didn't think to run a tape measure over it, have to stop listening to sellers stories.
I don't presently have my other 42" decks handy for comparison, sure looks a lot smaller than the 48" though.
thanks again for the assistance
gwest_ca
42" rear discharge models that fit the long frame tractors and each line has it's own parts list
1976 model 65-42MR01
1977 model 75-42MR01
1978 model 85-42MR01
1979 model 95-42MR01
1980-1983 model 05-42MR01
1984 model 05-42MR02
1985 model 05-42MR03
1986-1988 model 05-42MR04
The following could have a recycler kit 86001 added
1989 model 15-42RC01
1990-1992 model 15-42RC02
1992 model D5-42MR01 - Suspect this was an exported model
1993 model 78350
1994 model 78350
1995-1998 model 78350
1999 model 78350
2000-2014 model 78350
The following included the 86001 recycler kit
1991-1992 model R5-42RC01 - May be an exported model
1993 model 78355
1994 model 78355
1995-1998 model 78355
Garry
Aussie
thank you Garry
