Furious
Wheel Horse 1277
Furious
Have an opportunity to pick up a 1277 with from blade for $400. The tractor had been partially restored and is in great condition but...  The engine needs a new carb or a carb rebuild and the ignition wiring doesn't work. You have to jump the starter. Anyone have any thoughts?  This is my first experience with older Wheel Gorse tractors. Are parts available?  How sturdy/rugged are these machines?  Thanks
slammer302
I think you will be fine as long as its only a carb problem and wiring is pretty easy to get right on the older wheel horses we love pictures you should post sum if you have any
Furious
I'll definitely post some after I get it home.  Are 1277's good machines?  I plan on restoring this, but I also plan on using it as a worker.
squonk
Make sure the hydro is ok also
953 nut
:WRS:     The 1277 is a great  :wh:, in spite of the shortcomings it sounds like it is priced right. A wiring diagram can be downloaded here and carburetor kits are easy to come by. I would suggest that you try out the transmission before buying it. Put the front plow against a tree and put it in forward at high RPMs, it should try to bury itself, back up to it and do the same in reverse. If the tranny is good you have found a winner. The starter problem may very well be the ignition switch itself, if that is the case let us know and we can talk about options available to you.
:text-welcomeconfetti:   to  :rs:
  • Like 4
Furious
Should I expect durability issues with the hydro transmission?  Like I said, I plan on using this tractor to plow and pull at the very least.
Sparky
They are very rugged....but I personally wouldn't want make a 48 year old hydro tractor my "worker tractor". If you are going to make it a worker you will want to get the tranny good and warmed up to be sure its still strong when hot. Without pics I cant say if $400 is a good price or not and what one person calls partially restored may not be what another considers partially restored.
Mike.........
Furious
Thanks Mike. I'll send pics when I get it home.  I understand your concerns. I am very carful with my old machinery and will definitely treat it right. Since this is a side project, I can afford the time to rebuild the hydro should it need it. My concerns were more about overall durability if the machine. I don't want to spend the time and money investing in tractor with a known weak tranny. Sounds like they just need to be taken care of.
AMC RULES
Within reason, them ol' 1277's can make for some beastly :wh: machines.
                 IMG_3119.thumb.JPG.28cc3570be114e5dc3894IMG_3120.thumb.JPG.f7eee206dc1b08f047987        :wwp:     :WRS:
  • Like 8
Furious
Now that's what I'm talking about!  Can't wait to get it home so I can start tinkering. Where'd you get the front loader rig?  I
 don't need one, but I want it!
Furious
Just got the 1277 home. Maybe someone can answer some questions for me.
First, the engine is a K301 12HP. It runs, however, only at a set rpm, and only with the choke set exactly right.  Otherwise, it will start, run for about 5 sec then stop. If I move the choke quickly when it's dying, it'll run for another 5 sec ten die again. Do I need a new carb?  If so, any ideas where I could get one for the K301 engine? Mother spec umber is 47176.
953 nut
:woohoo:   Glad you got it. Chances are the carburetor just needs a good cleaning and a new needle and seat. You can pick up a kit on Ebay.   :wwp:
DennisThornton
Fuel delivery.  Pull the float bowl first.  Make sure the float drops and the needle is not stuck.  Look for crap in the bowl.  Clean it good, replace and check how it runs.  If still bad check fuel delivery to the carb.  If bad work your way back to the tank.  Fuel filter, lines, fuel valve if it has one.  Even the drain could be plugged.  Pull and clean the tank if you have to.  My last WH purchase wouldn't even start because of fuel issues from carb to the tank drain.  I cleaned and blew out everything and she ran fine!
Good luck and holler back with your results!
  • Similar Content
    • PWL216
      By PWL216
      Hi all. I have a 1277 that I pulled a loader off of. I’m not going to use the tractor and although it’s trashy, there may be usable parts on there that someone needs. Let me know what you need and I’ll see if I have it.
      I’m in MA and plan on going (first time) to the Big Show. Also, if you need something from the MA area brought to the show, I’m your huckleberry
    • Bostman67
      By Bostman67
      1967 Wheel Horse 1277 - Kohler K301S, gas engine, belt driven, hydrostatic. I had it running recently but then attempted some electrical work. I also cleaned it up by sanding some rust, dirt and grime off body and engine. Some new parts were added like a new choke cable, ignition switch, head lights, spark plug, battery and battery cables. I have new seat and some other parts that I will never use if sold. The implements include a tiller, snow thrower, mower deck. I've never attached these items. I have some belts and pulleys that came with it when I inherited it. It's easily accessible for removal and showing.
      IMG_1727.MOV
    • CB1993
      By CB1993
      Hello. I just purchased a 1277 today and was wondering if there was any info on the mower deck. Is there a manual for this deck? What kind of belt is used? I have attached some pics. Thanks for any input.
    • WHX??
      By WHX??
      @Achto and I took a little ride to title town this weekend to pick up this pair. Pretty much gave the seller asking price for the 1277 and he threw in the 1077. Both are far from pristine with the usual PO wonderments! Very savable tho. Both run and drive.
    • JayB
      By JayB
      My 1277 tractor has a Kohler engine but the ID tags are missing.  Any idea how to determine what HP this is?  Also what is the spark plug gap setting?
