KC9KAS
Belt Delima
KC9KAS
I searched "875 drive belt" and found the part number to be 6146 and a new number of 8005.
My local TORO dealer confirmed that 8005 was the drive belt for a 1075 and a 875....These are the only 2 tractors using this belt, and it is NLA!
During my search, the 8005 was said to be 1/2" X 72" and gave a Gates & a NAPA number.
I measured my belt and best I can see it is 70 5/8" long on the outside....Inside measurement would be minimally smaller.
Tractor quit pulling itself over the weekend and I had the belt routed under the guide on the guard instead of over the guide. My screw-up caused the belt to "smoke", although it did not break.
Can anyone confirm or deny the 72" length for a 875 drive belt??
squonk
Go to Napa and get a 4L720W. Done :)
KC9KAS
Thanks Mike & Garry......That is the NAPA number that was quoted here on :rs:
  • Similar Content
    • dannyo
      By dannyo
      Hi all.  I am new to the Wheel Horse world and I have a question about attaching a tiller to my 875 before I start spending money.  Based on what I've read so far, it sounds like I can use the RT-366 tiller without having the 8-3311 PTO assembly, is this correct?  If so, does the RT-366 belt attach to the hydrostatic motor if there is a double pully (#6887) installed?
    • D_Mac
      By D_Mac
      Picked this up today because I wanted the deck for my 875. The 875 has no deck so I figured this one is better then none at all. Question is what do I do with the rest of it??? 875, was told the engine needs rebuilding. Been sitting in a barn last 20+ years. Steering wheel is broke. Both front tires are shot and coming off the rims. Original paint. Plow needs the arm to turn the blade. Its repaired in a fixed position. Worth more in parts or as whole? Not sure I want a big project. What do you all suggest???
    • KC9KAS
      By KC9KAS
      My 875 is missing the small spring that is attached to the cam/neutral plate.
      The part number is 1230 and NLA.
      Anyone have one or know the dimensions of the spring?
      Thank you!
    • KC9KAS
      By KC9KAS
      ISO of hydro motion control lever bushings.
      These appear to be parts # 5666 (nylon) need 2, # 5983 (Nyliner) need 2, # MW2195 (bronze) need 1.
      Please PM me here.
      Thanks in advance.
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
