kudzu3
Gas shutoff
kudzu3
Do you shut off the gasoline from the tank every time you use the tractor or just when it is going to set a long time without use?
KC9KAS
Depends on the tractor....some have a fuel leak, so I shut them off!
groundhog47
I shut mine off every time on both I use as it seems to stop the intermittent needle stick situation (which may clear now that have started using ethanol free). I still smell gas when get the hood open but see no dripping when sits awhile before use. Both tanks have the "baffle" piece in lid. Till I run it down I'll still turn the valve off and run a bit before shut down to relax needle on seat.  :twocents-twocents:
