jusjeepn 59 #1 Posted November 15, 2008 Been out of town for awhile and not had time to tend the horses. I finally got started on the dozer blade extension fro the 520H. Got this far and decided the bracket's were going to be to weak for the blade I'm building (60"). So after 2 hours of bending cutting and grinding, I scrapped this idea. Here is what I came up with instead This only took about 45 min. to fab up and weld together! After spending half the day on this and having a boat load of material left, I decided to fab up a little double wide action for the 69 Electro 12. The fab juices were flowin as well as the coffee and this is what I came up with! Dual turf tires with chains and a 42" dozer blade?... I just may have to make 2 60" dozer blades Share this post Link to post Share on other sites
BairleaFarm 339 #2 Posted November 15, 2008 looks good. pretty neat how you moved the p/u point back Share this post Link to post Share on other sites
dgjks6 6 #3 Posted November 15, 2008 That looks great. I wish I could weld. It looks almost like the factory set up I just traded for a rear mounting bracket. One question though, how did you get it past the bar that the original plow mounted with? That bar is welded on my plow. Does the bar come out or did you take it out? I have never seen one for sale on ebay. Bet you could make some extra $ by fabbing a few more. Greg Share this post Link to post Share on other sites
jtmoyer 1 #4 Posted November 15, 2008 I have never seen one for sale on ebay. Bet you could make some extra $ by fabbing a few more. i would buy a set, although i am thinking about mounting the plow on my fel. jason Share this post Link to post Share on other sites
Rollerman 290 #5 Posted November 15, 2008 THe plow extension & the dual wheel kit both look top notch. Make sure to add pics when you build a 60" snowblade. I have a 56" snowblade on my 520H now ready for plowing duty "thaks Greg" & can tell you thats awkward one to park. how did you get it past the bar that the original plow mounted with? That bar is welded on my plow. Does the bar come out or did you take it out? Greg the older plow frames had a removeable pin...your's is a later style & is welded. Share this post Link to post Share on other sites
htopjimmy26 3 #6 Posted November 15, 2008 Yeah, I was going to also mention that my plow was also welded and I'm forced to either use the factory design extesion or grind the weld off and try to get the shaft out, or pony up big$ for the toro part . Share this post Link to post Share on other sites
Stigian 1,234 #7 Posted November 15, 2008 Nice fabrication work Pat keep them photo's coming :D Share this post Link to post Share on other sites
jusjeepn 59 #8 Posted November 16, 2008 Thanks guys!!!! I will probably go ahead and finish the other brackets and post them for sale! they should be sufficient for a 42" blade, just not enough for a 60". I started the 60" today and started a new thread! Share this post Link to post Share on other sites
