kcuttuck
C 121 stalls, floods
kcuttuck
My engine floods and stalls when I am on a hill mowing, leaning to the left and it is not much of an incline. Any ideas?
Edited by kcuttuck
JC 1965
i would check the fuel pump and clean the carb to start.
boovuc
The float will do this if there is gunk in the bowl. Give the carb a good cleaning as suggested above!
kudzu3
My '74 B 80 does the same thing. Runs great on level ground but when starting up an incline, stalls, blows black smoke and sometime just floods out and dies. I've done everything short of rebuilding or replacing the carb but nothing has fixed the problem. I think maybe a new carb is the best and maybe the easiest fix. :eusa-think:
Horse46
I was looking at a carb rebuild on the Tube, and this guy was making sure the float was level, could this be an issue if the problems are on hills and ok on flats?
Maybe if the float is say to high when going up a slope this could cause it to flood?
I'm pulling at straws here, but maybe someone might know if this can happen?
kcuttuck
It ended up being the float was full of gas. I replaced it. Runs awesome. Thanks for the input.
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
