papaglide
522xi trouble
papaglide
Well I hooked up Lowell's clevis hitch and cable and went to start my 522xi. It made a few clicking noises and then nothing. It won't turn over and the lights don't go on when the key is turned. I checked the safety switches, PTO, etc and all are ok. I will add that for about a year now, when I swould go to start the tractor the starter wouldn't engage right away all the time. Sometimes it would make a whirring sound, I would turn off the key, then turn the key and it would start like normal. Is it the starter?
doc724
I think there are two things going on.  You could have a bad ignition switch.  Recall that the lights are part of the switch on this model.  I think John Matthews may have had some ignition swith problems with his xi's.  Your starter could be bad or going bad or maybe the brushes are frozen to the armature due to inactivity.  My C141 had the later problem after 4 months "in storage" over the winter.  Of course your xi has a new, modern and smaller starter than the Bosch starters that were on the old K series so maybe the frozen brushes are not a problem with the modern engines.
JERSEYHAWG /  Glenn
I like the defective switch possibility. Is there a starter solanoid. Reminiscent of the old car start problems from years back. You would have to wack that solanoid.
Glenn
Edited by JERSEYHAWG / Glenn
boovuc
Hi Mike,
Ignition switch possible but, if it was starting just before you installed the clevis hitch, I would look at the seat safety switch. You may have had the starter issue with a few clicks then have nothing due to an interlock issue. Two things at the same time maybe? I always look in the area I was working on when right after the work, I have a no start issue.
shallowwatersailor
Just to clarify, I had an ignition switch problem on a 520-H. The 518xi did develop a bad seat safety switch. Try a simple jumper around it
Mike, go to the basics first such as battery voltage. With the "chatter", it sounds like insufficient voltage.Just like Boo said, what was the last thing touched.
papaglide
I checked the safety switch and the jumper is good. I didn't mess with any wiring installing the clevis, I actually had the tractor running a few times while installing.
I think that I am leaning toward checking the ignition switch. Can I put a tester on the switch leads to check for current?
Dennys502
I had problems with my 523xi diesel ignition switch. it wasn't making good contact and wound up melting the plastic on the connector - had intemittent starting issues.
Brian01
Could be as simple as a loose or dirty ground/connection. Check, clean, and retighten all connections.
ericj
if you started the tractor several times while putting the clevis hitch on you may have run the battery down without recharging it. check voltage on the battery 1st, do the simple stuff before digging in deeper don't make it hard on yourself. good luck
eric j
papaglide
Well, I finally have some time today to dig into this thing. First off, buying a voltmeter to check the battery.
RMCIII
Mike - I'm just going to assume that you checked the 20amp. fuse? My 18 did the same thing when I had it. I started with the seat switch, brand new. Then I started testing the ignition switch. All checked out fine. Went to the starter and checked it. That was fine. Finally I decided to start pulling fuses. When I pulled the 20amp, one side was completely melted. < To this day I have no idea what happened. I replaced the fuse and it fired right up. It could have been a bad seat switch that lead to it being fried, but I can't be positive.
RC
papaglide
That happened to me allready, a little while ago. But I did check the fuses again: all are A ok. Right now I am waiting for tomorrow so I can get a replacement ignition switch.
JERSEYHAWG /  Glenn
Mike, thats good, I have been waiting for you to post what it is. lets hope its the switch, problem solved and done.
Glenn
papaglide
Well, I replaced the switch and still nothing. Battery is good. The jumper is good. The fuses are good. I am truly puzzled.
Brian01
Not to be a smart @$$ or anything, but did you check fuses with a test light? Sometimes they look good but aren't.
I would also check all ground connections..take them off n clean them with wire brush or sand paper and retighten
Also check the saftey switch connectors themselves, making sure they aren't bent and touching, that'll "short it" and make it not do anything
papaglide
Brian, I didn't even know that fuses could be checked! I will check that out.
I just looked at the service manual. One reason it states is that the tarter selenoid needs to be replaced. Is there an amy to check this?
Brian01
lol yes, get you test light, make sure its grounded good...leave the fuse where it is supposed to be....ontop of the fuse itself you can see a little bit of metal on each side..touch your testlight to each side....if it lights up on both sides, then its good, if only on one side then its bad
papaglide
Thanks Brian!
Brian01
Not a problem...That's what we're here for
Forest Road
Did you have to remove the rear fender? If so you could have unplugged the neutral sending switch. It pushes against the speed control cam. Sent from my iPhone using Tapatalk
papaglide
Fortunately I didn't. Lowell's  hitch is installed from the underside of the tractor.
papaglide
Well after much messing around I am led to believe that it's the starter selenoid. Battery is good , safety is good, fuses are good, switching out the ignition switch solved nothing. Only problem is that on parts tree the selenoid goes for $296!!!!!!! I might as well sell this thing and buy another tractor for $300!!
Forest Road
Pull the solenoid and go to your local small engine shop. Maybe even auto parts store and get a universal solenoid. Or just push the tractor east to my camp in the AP and I'll tend to it :) Sent from my iPhone using Tapatalk
JERSEYHAWG /  Glenn
wow, that was my original "guess".  I'll  be darned if thats it. Just like way back in the ol days. Mike, you did go through the steps.
Kevin threw a good idea at you. A universal one.  Good luck.
Glenn
  • Similar Content
    • jmack
      By jmack
      I’m looking for a front grill and bumper for my Xi. Let me know if you have one.
      I’m located in Central Ohio.
      Thanks,
      Jonathan
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • jmack
      By jmack
      I have a 522xi and noticed the muffler is glowing red as shown in this video? Should I be concerned and fix it to normal operating temps or is this expected?
      Thanks,
      JMack
      IMG_1788.MOV
    • ToroMan
      By ToroMan
      Good afternoon, looking for some help regarding a plow assembly for a 1999 520xi model # 73542.  I'm told that a traditional Wheel Horse plow assembly will not fit this tractor, that the xi series requires a special plow assembly.  Problem is, most of the people selling plow assemblies don't seem to know what they have, and I don't know what I need!  I have included the supposed model numbers pulled from the Toro website, including that of a retrofit kit, but I'm not sure what that retrofit kit does! Does it enable me to fit a traditional Wheel Horse plow to an xi model? Don't know.  One guy selling a plow knew what type of plow he had and told me it would not fit my tractor, stating "Lift link and handle are in the wrong locations."
      Any help would be greatly appreciated. Just need to know what the hell I'm looking for, which might help me find it!
      From Toro site:
      Model #: 79355
      48" Snow/Dozer Blade
      Model #: 95-4090
      48" Dozer Blade Retrofit Kit
      Thanks!!!
    • Earthling
      By Earthling
      Hello Everyone!
      The machine sold to another buyer.  I really appreciate your thoughts and information.
      Thank you!!
