King Horse 22 #1 Posted June 29, 2015 So I put new stuff on horse today. I also wired up a new Napa ignition switch. I noticed the voltage regulator is warm when the hot wire is hooked up. On another note before I put a new ignition switch on, the key was left on and coil starting smoking. Any ideas on what happened? Share this post Link to post Share on other sites
slammer302 2,154 #2 Posted June 29, 2015 i know leaving the key on will burn up a coil i know this from because its happened to me once. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,123 #3 Posted June 29, 2015 Anytime I do electrical work like what your doing...I always pull the neg/- cable off the battery.......just in case. Share this post Link to post Share on other sites
