608KEB
520H hour meter doesn't work
I have a 1994 520H. The hour meter works if I take a ground wire from another ground source. I looked through the 520H wiring diagram and found that the hour meter ground runs into the oil pressure switch. I have taken the 9 pin connector apart. It's in good shape. I cleaned it and used electric contact grease. When I turn the key to on, I noticed that the oil pressure warning light does not come on. I'm guessing that the ground running to the oil pressure switch is at fault. Is this correct or are there other possibilities?
Edited by 608KEB
First, check your fuses. If it is the same setup as my 416-H, the oil pressure switch has two circuits. One is closed when the engine is off and until the oil pressure reaches 5 psi. That causes the oil light on the dash to flash when the key is turned on, and until the engine is started and oil pressure builds up. When it reaches 5 lbs, it opens turning off the light. At the same time, when the oil pressure reaches 5 lbs, the other circuit closes. This connects the ground side of the hour meter.
If the oil light does not come on with the key on and engine not running, I would suspect that the switch has gone bad.
When the key is turned on the oil warning light does not light up. Do I remove the shroud to get at the switch?
Edited by 608KEB
Did you ever figure this out? No ground at the hour meter. But the light blinks when the key is on/ engine off. Trying to fix the faulty ground at the hour meter without disturbing the original wiring
Posted (edited)
No, I never did figure it out. I put a new oil pressure switch in. I didn't know how to test the switch. To see if it opened and closed properly. It's supposed to open between 2 and 5 lbs of oil pressure. The hour meter does work as it should now. So it wasn't grounded. But when I turn the key to on, the oil pressure switch light does not flash.
Edited by 608KEB
  • Similar Content
    • By mmmmmdonuts
      I was talking to my colleague the other day and I knew he had a wheel horse tractor. He was having issues with the transmission leaking fluid and there is a bad hub. But other than that it is in decent shape considering it has 2100+ hours on it. Needless to say he bought a new zero turn and no longer needs his horse so he gave it to me for FREE! He was the original owner and has all the original paperwork. It is a 1991 520h and I am still shocked how quiet it is compared to my Raider 12.
      Anyway the good stuff...the pictures.
    • By Rich16
      Hi! I'm a new member and sure this has been addressed here but how do you remove the gauges on a 520h '91?
      I just bought a replacement tach on top right (sticking with all Toro to match) and almost cried when I saw how difficult replacement seems to be. Saw one post about bending the dash cover and loosening the metal piece behind the gauge flange but I tried and don't want to take the chance of breaking the dash cover. Is it necessary to remove the steering wheel and maybe the hydraulic levers to get to them? The voltmeter isn't registering either (bottom left) and it's even more difficult to get to so I don't think bending anything will work. Everything else works perfectly. Help!
      Just purchased this 520h with just over 600 hrs and really worried about the rear valve seat issues but it purrs like a kitten and is a delight to hear - love it! The owner mostly restored everything and I'm finishing the job.
    • By EricMN
      For Sale - 520H with 48" mower deck, Front pusher blade, Belly grader blade, rear tiller.  Runs great. Sold as a package. Additional pictures upon request.
    • By Goat 2141
      Were doses this hose go
    • By Goat 2141
      Where is the oil sensor switch
