John Galt
Has anyone done a gt14 diesel swap
John Galt
I'm kicking around the idea of swapping my kohler 321 k 14 horse power motor for a diesel engine. Haven't figured out why my motor won't fire up. My thinking is if I have to drop a few hundred bucks on my old kohler engine, it might just be better to get a new one without spark problems.  I was wondering if anyone else has done that swap in a gt14 and open to any thoughts on the subject. It is a working tractor. Or it use to be.
Stigian
I have never tried it but a diesel powered Gt-14 sounds a great idea :thumbs:
callum12
a diesel GT14 would be amazing! there is a guy on youtube that has made a diesel sears. he used a Chinese clone engine though.
If i was to do it I would go all out and use either a Lister LT1 or LD1 (lister later became petter). they also the the Lister LT1 in a 2 6 cylinder format as well. I reckon if you could squeeze a 3 cylinder in there it would become my favourite wheel horse of all time as it would sound like a full size vintage tractor!
here is the 3 cylinder, might be  bit big though:
lister-petter-3-cylinder-eng70ece144-1_z
the newer  LT1 stater motor can be installed on these:
diesel-engine-single-drum-air-cooled-577
the older LD1 not sure about starter motors:
I might have got a bit carried away here! :) sorry!
callum
SALTYWRIGHT
 I HAVE DONE A 417-8 AND A 1054 TO DIESEL. I HAVE A GT-14 AND WILL DO THAT NEXT.
John Galt
Saltywright, What diesel engine did you use? What differences in performance do you notice? With the problems of ethanol and gas becoming stale it might be a better alternative if it's cost effective. I need my tractors to work.
SALTYWRIGHT
HI.....I USED THE CHINA KNOCK OFF. A 10 H/P IN THE 417-8. A 6 H/P IN THE 1054. I WILL PUT A 10 H/P IN THE GT-14. I NEVER FELT I NEEDED MORE POWER. IN 1974 I PUT A 6 CYL. DIESEL IN MY CORVETTE BECAUSE OF THE GAS SHORTAGE. THE LAST BOAT I WAS CAPT. ON HAD 2 860 H/P DIESELS.     RUSS
callum12
thats what this guy used on youtube with his sears, i think the diesels run slower so to produce 10hp they actually make more torque? (something like that anyway)
callum
953 nut
:banana-gotpics:    have you posted these?
SALTYWRIGHT
MY DIESELS RUN 3600 R.P.M.
shallowwatersailor
On Sunday I installed a Tiny Tach Diesel Tachometer/Hour Meter on my DC-105. This is the new version that has a flash memory and is connected to tractor's battery instead of the old internal battery with a five year life span. I can now install an ammeter in place of the old hour meter.
I had originally bought it to install on the 523Dxi but realized that the Carol Stream 10 hp diesel uses an injector pump as well. The inducer (6 mm size) is installed on a straight portion of the fuel line. Because I am still breaking the engine in, I was curious as to the rpm I have been using. The manual recommends to not run at high rpm until twenty hours of use. It has 6-1/2 hrs on the engine so far. Because it counts the pulses with the transducer, I can't add the other six hours like a gas version hour meter though. While breaking the engine in, I try to make three passes up and down my street which take approximately 1/2 hour! Pretty boring at this point and wish there was a youngster around to do it. My dog has trouble with the clutch and can only manage a hydro. :ychain:
DSCN3164.thumb.JPG.ec0847f9102ceeb16c2cfDSCN3158.thumb.JPG.a272160d78016bafe0ed2
Edited by shallowwatersailor
steamdriven23
So has anyone completed a diesel swap in the GT14?  I too have been kicking that idea around.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Bill D
      By Bill D
      I have a GT1800 that I have swapped an M14 into.  The original drive belt is too long for the Kohler.  I tried a 7473 belt and that was too long.  I'm guessing I need an 81" belt.  Does anyone know for sure?  I'm thinking it should be the same length as a 314H?   I'm trying to avoid multiple trips to TSC with the price of gas.  Yes, I do have the correct hydro pulley on the Kohler.  Thanks.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
    • swisstrac
      By swisstrac
      looking for info/help re securing a front wheel bearing/race for  GT14/ 1971;  any info would be much appreciated..
