lawnboy63
C195 wheel weights
lawnboy63
I've been looking for wheel weights for a C195 for some time with no luck so I'm thinking of having some cast. What I was hoping is that someone who actually has a set could take extensive pictures and provide detailed dimensions so that the pattern maker could replicate them. Any help would be greatly appreciated.
Thanks,
Tom
Brrly1
Actually I'm having the same feeling, already started the process.
lawnboy63
How far along in the process are you?
Where are you located?
Tom
callum12
If you two could get together and get them cast by the same company you would probably save a few bob. I was looking at getting a plaque cast for my tractor in memory of a friend and it was cheaper to get 10 cast than it was the one.
you could get a small batch together, get people who wants them to pay a deposit or something??
have fun finding a business to cast them, that sort of industry is really fading unless its mass production unfortunately,
callum
Trouty56
I have a set of 15 inch wheel weights but I doubt they are Wheel Horse weights.....have them for the D180.....you want some pics of them??
lawnboy63
Trouty56, go ahead and send me some pics of the weights.
Brrly1
Basically just starting, I'm in Toledo as it says. Curious to what your price is versus the price I pay?? I've done aluminum and cast. Know people at each foundry
Trouty56
Well....I hope this helps you a bit.....the lip is 1 inch high.....guess they weigh about 60 lbs....maybe more/less.....
20150519_083322.thumb.jpg.ee1bd2ff803f74
2 inches deep at the access holes and bolt holes...bolt holes are wide enough to secure a carriage bolt
20150519_083305.thumb.jpg.4b16836a8460e2
12 inches across and fit inside the tire circle.......
20150519_083217.thumb.jpg.f0eba79d60c794
Brrly1
Thanks!!!
lawnboy63
Pics look great.
Diameter of 6 holes, size of carriage bolts?
lawnboy63
Opppss, center distance of carriage bolts?
Trouty56
The holes are 11/2 inches in diameter....the bolt slots are 1/2 inch wide....10 inches between them....
lawnboy63
Trouty56, would it be to much to ask for a pic of the backside of the weights?
Trouty56
Dang...you are making this hard....lol....I'll try to get er dun this evening.....I think they are just flat.....
Brrly1
Look at your wheel, it will tell alot of that
Trouty56
Ok,,,,the lips are 1 1/4 inches and taper to about 1 1/2....the front lip extends about 1 inch....the rear is 3/4......heck they might be the same......they are HEAVY.....
20150519_191107.thumb.jpg.0b55d603922c04
20150519_191127.thumb.jpg.eb031bb1e9f5f0
Edited by Trouty56
Brrly1
You think they around 50 to 60 lbs?
Trouty56
Yes....I do.....
lawnboy63
Bob, thanks for all the pics and info that you provided. I've got a meeting scheduled for Monday at the foundry. Just from the conversation I had with them their thinking cost for a weight of 50-60 lbs would be around $1 per lb. plus the cost of the pattern.
After I talk with them I may decide to make my own pattern.
Tom
Brrly1
If you can get cast weights at that price sign me up
Trouty56
Tom
Looks like the indent on the top is more like an inch on that last photo......if you made it flush across you would probably gain 10-12 lbs..... Edited by Trouty56
tbarnhart
The indents are cast that way so that the weights will stack and still be centered. You could put 2, 3, or more on each side if you had longer mounting bolts. I don't think I would make them flat, just get a couple more cast and stack them.
Trouty56
​I learned something today....thanks!!!!
jeremi3210
Here is a pic of mine. Probably all of 60 to 75 lbs, I found them at the scrap yard for .25 a pound. I wish I could find more like that!
Brrly1
Any replies on the casting prices??
