sluggo
broken Steering bracket
sluggo
The lower steering bracket has broken on my 1993 WH 310-8. I hit a tree while turning and the left ear that attaches to the frame has sheered off. The local Toro dealer wanted $97 including shipping.  A guy at work has offered to weld it for me. Will remove and try to weld it. Not sure if it is cast iron or steel.
Any advise? Anyone else have this issue ever?
I'll post an update next week to let people know how it turns out.
stevasaurus
They are cast iron.  You should be able to weld it...or someone may have one for sale.  I found one for my B-100 a couple of years ago...they are out there.  :)
oldredrider
If the welding doesn't work out, send me a PM. I've got some laying around.
Depending on where you live, might be a short drive to pick up.
squonk
My C160 has both ears broken off. The p/o made some steel plates and used them to clamp the bracket down. Worked so well they are still there and I've had the tractor 6 years. I have 3 or 4 spares laying around. I'll change it someday
shallowwatersailor
You might care to replace it  (88-2710-03) to tighten the steering. It usually gets worn over the years. I found one seller online for $68.18 plus shipping.
sluggo
I like the steel plate idea. I may try it this weekend. It may save me from disassembling everything.
I saw the $68 dollar option a couple of days ago. Still a ridiculously large sum for a small amount of metal.
stevasaurus
Got mine for a bottle of my homemade wine.  :)  $68 is crazy high.  :)
woodchuckfarmer
Have it welded , Ive done it and no problem......Wayne
857 horse
home made wine???
what have i been missing???
Never know.....BIG SHOW is coming up....
im gonnna be there.....and no wheels are gonna fall off??
did he really say home made???
daveoman1966
I can send you a good replacement steering block...not broken or welded.... for $35...SHIPPED TO USA ZIPS
My direct email is:
daveoman@windstream.net
  • Similar Content
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • DennisThornton
      By DennisThornton
      One of the most detailed I've seen.
      https://www.homemadetools.net/forum/garden-tractor-loader-videos-85395?utm_source=newsletter&utm_medium=email&utm_campaign=05-21-21&utm_content=05-21-21-181510&fi=181510#post181510
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
