johnclinster 0 #1 Posted May 8, 2015 14 hp, I have changed everything electrical except for the starter, the problem started when I was trying to turn the engine over, it cranked fine then would just click after a failed attempt, Any thoughts on what the problem could be? Thank you Share this post Link to post Share on other sites
KC9KAS 4,741 #2 Posted May 8, 2015 Low battery. Bad/corroded connections. Bad solenoid. Share this post Link to post Share on other sites
johnclinster 0 #3 Posted May 8, 2015 Okay I have a new battery, solenoid, and cables, is there anything else that could be the issue Share this post Link to post Share on other sites
