johnclinster
1972 Wheel horse Bronco, starter problems
johnclinster
14 hp, I have changed everything electrical except for the starter, the problem started when I was trying to turn the engine over, it cranked fine then would just click after a failed attempt, Any thoughts on what the problem could be? Thank you
KC9KAS
Low battery. Bad/corroded connections. Bad solenoid.
johnclinster
Okay I have a new battery, solenoid, and cables, is there anything else that could be the issue
