73400 toro wheelhorse no spark but turns over fine
By
radweldgod, in Wheel Horse Electrical
Similar Content
By BrianKoch
Hello gentleman,
Problem: will not crank on its own, will crank with jump box—but still not fire
Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
I have my test light out and am probing around.
There is no power at ignition/magneto wire or the ignition/starter wire
There is power everywhere else
By Jeff-C175
Detailed wiring from the Demystification Guide #492-4509
4 pages 1.4MB Color
p7-67 to p7-70
Onan powered
1989 416-8 model 31-16O801
By trident
Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
By grasscuts
Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
By jakester
hello all I'm a new owner of a 312-8 tractor, have starting problems, came across a very small, what I believe is a relay between the battery and the dash,its about 2/3rd size of a cube of sugar silver on the outside blue on top with a hole bout the size of a pea, theres 6 pins with wires connected to it on the bottom do not know what this is any thoughts? I cannot determine the exact year of this machine for there is no tag anywhere only tag on engine kohler magnum md #m12s ser# 170370459 spec# 471527 I figure its mid to late 80s to early 90s. of all the wiring diagrams ive looked at it does not show any thing like what I just described also can that little circuit board be removed that's like a test point for idiot lights? any help would be appreciated jeff
