glenn27
Measurement for a front blade on a 520 model?
glenn27
Hi--If anyone has a front blade on a 520 model--could they just measure from the rear support rod (that hangs in the quik attach hitch)--to the center lift bracket??
:hide:
I'm trying to help a man with a blade, and I'm getting a couple conflicting visions....
Thanks for any input...
glenn
glenn27
The one he looks at is about 29" difference, but the one mounted on my 70's C-120 is only a little over 25" from back rod to lift-link bracket...WTH?? :hide:
Jim_M
Glenn,
I'll try to remember to get you a measurement today after work.
Jim
glenn27
Thank You--Jim.
Jim_M
Glenn,
I measured 24" from the center of the rod on the rear that goes into the hitch to the center of the lift link hole on the frame. I hope this helps.
Jim
glenn27
Jim--that is it, then--mine varied between 24-1/4 and a little over 25" on two different applications.
Thanks-mucho! :hide:
glenn
