rmaynard
9-Pin Connector Kits for 300/400/520 Series
Direct fit replacement for the notorious 9-pin connectors that fail in the 300/400/520 series tractors.
These connectors are the exact replacements for ones used by Wheel Horse. If you are replacing both male and female sides, there is no problem using any 9-pin connector with .093" pins. But if you are only replacing one side, this will fit your existing OEM connector. All 9-pin connectors are not the same
Kit includes both male and female connectors, and 9 each male and female .093" pins.
CLICK HERE TO ORDER
Note: Pins can be soldered, but if you need a good open barrel type crimper to install them, contact me for a good source.
Thanks!
Edited by rmaynard
  • Like 8
I'm going to be in for a couple of everything you sell once you get your lug nut kits up for sale! What crimp tool do you recommend for these?
Brandon,
For crimping open barrel terminals and pins, I use this:
http://www.amazon.com/dp/B0050KDKUC/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=PSE0MLM1C1F3&coliid=I1GXDCKO2XQJS5
To remove the pins from the connectors, I have one of these:
http://www.amazon.com/dp/B0094MIS9U/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=PSE0MLM1C1F3&coliid=IMZR1SP7N48SN
and one of these:
http://www.amazon.com/gp/product/B0009OR906/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Either one will work fine.
Edited by rmaynard
My supply of 9-Pin connectors is dwindling. Less than 10 left. I have ordered more, but they have been back-ordered for five weeks. That does not sound good since there is only one known distributor carrying them now.
