dunk50
Looking for WH Parts source!!
dunk50
I have been going through a 312-H that I bought recently and need some parts. Can someone point me in the right direction for a source. To many little parts to hunt for individually!!  Thanks
Kelly
I sell used parts send me a PM with a list, I will see what I have.
Pollack Pete
Contact Scotty on this site.He claims he can make any part you need.
dunk50
I don't think I need anything MADE but just wheel horse specific parts
Lift link for plow  (short)
Seat hydraulic strut
Rear taillight
Momentary ck light switch
P.T.O.  lever bushings
That' why I said source. Thanks for the suggestion. Will ck with him.
bmsgaffer
Unfortunately you will have to start hunting for parts.
Bushings are still available from Toro (the parts list is available in the manuals section of this website or on toro parts master)
Strut, lift link I would check with Kelly
Switch I'm not entirely sure, but someone on here does.
GlenPettit
Kelly is the man with almost everything in Wheel Horse parts.
Next month is the big swap meet in Mentone, IN – lots and lots of Wheel Horse parts there,
and Kelly usually comes down for it too with a big trailer full of used parts . . . you should
be able to find nearly everything you might need there.
Chuck McColly will be there with his big 'School Bus' full of new parts/supplies for our tractors.
I think there were about 50 trucks/trailers of just Wheel Horse, and then about the same number
of sellers for 'all other brands combined', lots of knowledge, a very nice show & free admission.
localdj77
Ooooooooooo........I HAVE to go to this!!!!
Forest Road
Lift link for your plow is nothing more than a flat bar w 2 holes in it. A couple of pins and you're in business.. Drill a few holes at one end so you can try different lengths without having to make several different bars. I use the same lift link for my 50" grader and snow plow.
Sent from my iPhone using Tapatalk
Kelly
I'm sure I have some of the parts you need send me a message
dunk50
Glen I definitely plan on going to Mentone, Tank, I thank you for the link to parts tree. And Kelly, at this point I am looking for a lift link, probably the short. Was going to ask a few if anyone uses the long link for down pressure. I am on mostly concrete and asphalt and down pressure sounds interesting. Also looking for 23X9.50-12 tires. Also the gas strut. I really don't know if the strut is a needed item or just a nice thing but The one I have is definitely worn out. Ordered the decals already and hope to have it done before Mentone so I can gather parts there if I still need any. OH, also looking for decent single stage blower. Thanks for your time guys!!!
bobert94
As far as tail lights look at myer or walmart they both carry aftermarket tail lights in the automotive dept that are a direct fit!
  • Similar Content
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
