cch750 0 #1 Posted January 28, 2015 Hello I have a rotted out 48"deck model number 1548SC03 and serial number 2002754. And have a older solid shell 48" deck model number 65-48MS01-06513 and serial number 6329. Can I install all spindles and hardware from rotted one to solid deck? It looks the same. Share this post Link to post Share on other sites
Don1977 604 #2 Posted January 28, 2015 Most of the parts will fit. The slide that tightens the blade belt is different. The top nylon pieces the contain the slide are no longer available for the 65 deck. You may be able to turn them around if only worn on one side. I have a 75 series deck that I have the metric spindles from a late model deck installed. Share this post Link to post Share on other sites
cch750 0 #3 Posted January 28, 2015 Ok great thanks Share this post Link to post Share on other sites
