jm46322
replacement turf tires
jm46322
i am sure I am bringing up an old topic but what are my choices in replacing a set of old b f Goodrich 6x12 turf tires on my 604 that is getting a barn fresh redo.
its tires are so dry rotten that tubes are not a way out. are there any new ones getting made out there that look like the older ones, I really like the aggressive thread pattern on them. think I looked at every site on the internet and cant find any so I figured I ask the pros
thanks
520HC
Miller Tire
speedyleedy
You might fine a used set off of someone on here also .
kudzu3
My tire guy has a few catalogs that have about anything you could want, you may want to check your local tire store catalogs. Good luck.
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Need a pair or rear rims for 518xi, 520Lxi, 522xi, 523dxi, GT18, GT20, GT22, GTD23D, tractors.  Can take new old stock, nice used, or used that need refurbishing.  Anything will be fine.  Needs to be within 2 hrs of Erie, PA, or shipping available.
      Thank you,
      Mike.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
