jdmitchjr@6dlam.com 5 #1 Posted November 3, 2014 (edited) Yesterday, after doing some work on my D-180 with an Ark loader, I went to pull it out of the garage but the bucket would not lift. The pto belt was not engaging at all. Closer inspection revealed that the tension adjustment bolt is missing and likely someplace in the grass between the shed and the garage. The bolt goes through the tabs shown in the photos below as indicated by the yellow arrows. The bolt part is easy but my sense is that there should be one or two springs as well. None of the manuals I have show this part of the pto pump and I do not recall what was there before. The question is whether there should be a spring over the bolt: between the tabs (blue arrows) and/or between the top of the top tab and the nut (green arrows)? Thanks for any input. Regards. Edited November 3, 2014 by jdmitchjr@verizon.net Share this post Link to post Share on other sites
