some-beach! 0 #1 Posted October 18, 2014 Went and picked up Dad's old WH 417-A [1986 I think]. Hasn't run in 2 years. Battery was still good for a few cranks then I had to jump ~ currently on charger. When I turned the key ~ nothing ~ except for headlights worked when switched on. I used a screwdriver to jump across the starter relay and it cranked but no spark/no start. The brake pedal is tight although I did get it to move a little with force and WD-40. I know there's safety switched and I also know at least one was bypassed at some point if memory serves me. I can't tell much but something isn't allowing the key to crank it and there's no spark ~ not sure if a safety switch would make both inoperable. It ran great a couple years ago until left sitting outside in the elements. What safety switches are there? I think there was a PTO / neutral switch and a park brake safety switch. I don't see a seat switch or maybe that was the one bypassed???? I'm taking off the instrument panel and shift plates to get a better look. Might just be a bad connection or rusty connection. Can't wait to hear it run, access the condition and begin to restore 'Ol Red' Share this post Link to post Share on other sites
Save Old Iron 1,563 #3 Posted October 18, 2014 If the battery has been severely discharged for several years, capacity or "cranking time" may be near zero. Slow charge the battery and measure the voltage across the battery while cranking. Less than 10 volts indicates a compromised battery in need of replacement. Share this post Link to post Share on other sites
some-beach! 0 #4 Posted October 19, 2014 Time to get an operators manual and a wiring diagram I guess............... Share this post Link to post Share on other sites
AMC RULES 36,945 #5 Posted October 19, 2014 Check for it in the manuals section here on Share this post Link to post Share on other sites
Amanda 81 #6 Posted October 19, 2014 Welcome to redsquare Share this post Link to post Share on other sites
Geno 1,928 #8 Posted October 21, 2014 Sorry so late, I was out of town but hello and Share this post Link to post Share on other sites
Sparky-(Admin) 19,532 #10 Posted October 22, 2014 Mike............ Share this post Link to post Share on other sites
