bell
bell's 855
bell
I bought this 855 that was advertised as a 8hp Kohler on a junk, rusted out Wheel Horse. I bought it for the engine, but when I saw it... I knew I had to save it. :banghead:
bell
Yesterday, I cleaned/ tuned the carburetor and got it running PERFECTLY! :horseplay:
The hubs were a bit chewed up, so I used a trick that I learned from rustyoldjunk... I moved the hubs out about 3/4" to get some "fresh" keyway... Then, I mounted the AGs. :banghead:
I bought a new muffler at TSC, it is a AC-1 tractor muffler.
Next weekend, time allowing, I will partially tear it down for a fresh paint job...
saguaro
Looks good with the ag's and stack. :banghead:
Does it do a good job of quiting it down?
bell
Thank you!
It is MUCH quieter than the old muffler it had on it. It has a deeper tone also... It sounds GREAT. :banghead:
saguaro
She looks like a good project. I may have to put a hitch on my little car and do some wrangling up you way. I've only seen one other horse down here and I doubt he'd let it go. <_
bell
She looks like a good project. I may have to put a hitch on my little car and do some wrangling up you way. I've only seen one other horse down here and I doubt he'd let it go. <_<
Come on up! You can come by and check out the horses. :banghead:
saguaro
I may do that on one of my larks, been a while since I've been up that way.
Brian1045
Yo Jon...can you post a detailed pic of how you attached that muffler?
I like it! :banghead:
bell
Thanks, I'll post a pic as soon as I get it done... I still have to make the support bracket. I should be finishing it Monday or Tuesday.
TT
If it will help, I have some pics of a stack install on a big block Kohler/'68 Charger 12 (using a Farmall Cub muffler from TSC):
And here's a few of a flange mounted straight pipe with support brace on my old C-161 puller:
bell
That's what I was planning! Now I can see what it is gonna look like. :banghead: Thanks TT!
HorseFixer
Jon that stack looks :USA::banghead:
Duke
