  • ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoticons maximum are allowed.
    ×   Your link has been automatically embedded.   Display as a link instead
    ×   Your previous content has been restored.   Clear editor
    ×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By ebinmaine
      As stated in another section my honey went and bought herself a 657 a few days ago. Sunday afternoon to be exact.
      Runs and drives quite well and had a very serious and non negotiable issue.
      It's Oliver green with Ford gray wheels.
      Other than that the work should be minimal standard stuff.
      Well of course she started tearing right into the disassembling of the lucky little tractor.
      We started to show the daily work being done to it and then realized we should really start a new thread in the proper location.
      So here's a few before pics as a reminder.
      Here's the end of Sunday results.
      And a pic from Monday nights work.
      After this was taken she found some spray on paint stripper and emptied the can on it.
      We left it on for 24 hours or so.
      And found red paint!!
    • By Team70R
      Looking to get rid of all my Tecumsehs! The HH60 ran before I pulled it, just needed carb adjustments. Electric start! The other 2 appear to be H60s but are both in rough shape. One has a broken flywheel fin, stripped out oil plug hole and a seized governer. Other one has a broken crank or rod. Pm for more details! Pick up only, at this time.
    • By raymondvandervort
      HH60 cast block in very good shape, bead blasted and primed with zinc chromate primer,
      with some valve parts, dimensions available. Part numbers for this block have
      been:32176;32163;31789;32176;32176A;32176B;34761. Prepped for a project the customer abandoned.
      Also parts obtained for this project available:
      Gasket set 33235A
      Breather 28423
      condenser 30548B
      Screw 650697A
      Screw 650694A
      wiper 30549
      Breather tube 35350
      valve cap 30964
      valve cap pin 20810
      gasket 29673
      valve cap 27882
      oil seal 28460
      oil seal 27876B
      carb 631828
      valve spring 27881
      points 30547a
      governor spool 30588A
      breather filter 28424
      bearing 31793
      valve retainer 27883
      bushing 31461
      gasket set 33234A
      rod 31380C
      ring set 34854
      piston 31797B;345503;34531
      Gasket set 33235A
      Breather 28423
      condenser 30548B
      Screw 650697A
      Screw 650694A
      wiper 30549
      Breather tube 35350
      valve cap 30964
      valve cap pin 20810
      gasket 29673
      valve cap 27882
      oil seal 28460
      oil seal 27876B
      carb 631828
      valve spring 27881
      points 30547a
      bearing 31793
      bushing 31461
      gasket set 33234A
      rod 31380C
      ring set 34854
    • By Team70R
      Got the Chinese carb installed on my HH60 and had it running decent. Tried to get it to idle by adjusting the idle screw..Well now it's a bear to start and smokes like a frieght train in the event it actually fires... Fuel shut off is suddenly stuck open as well. Had some  sediment in the fuel filter, which doesn't surprise me.
      Why won't it start now??
