gumshoes
6hp tecumseh Blowbye
I have a new 657 with a 6hp Tecumseh that had a new short block installed several years ago. The tractor had sat for the past 5 years. I installed a new carb and changed the oil twice. The engine runs great and doesn't smoke. I am getting some oil coming from the breather tube. It doesn't do it all the time but when it does it comes out pretty good. I installed a new breather filter and the oil level is good. What could be causing it. Thanks guys...
Maybe a ring is sticking where it sat so long.  Use it for awhile and see if it clears up.  :)
I have two Tecumseh that do the same thing the one on my lawn ranger witch I've used quiet a bit this summer seems to have stopped now maybe the more u run it it will stop
I took the head off and cleaned the valves which were gross. I cleaned the head and the top of the piston. It runs great now.
That's the fast way to do it!   :text-+1:
Spoke to soon. After I ran it for a little bit it started blowing oil again. What doesn't make sense is that it runs so nice and doesn't smoke at all. Also it doesn't do it all the time. It will do it for a few minutes then spot for a few minutes.
Something must be trying to work itself out, give her time.  :)
Ya I hope so Geno. She runs so nice. I've been waiting to buy this tractor for 15 years. It belonged to my buddies dad and I told him 15 years ago that I would buy it when he decided to get rid of it. I hadn't seen it since and forgot what model it was. I was excited when I got the call last week. It has sat for the past 5 years and he installed a new short block several years ago. It did come with a near mint 1955/56 utility cart, a deck and plow. Have a great night.
I went to the mid month meet and greet and there was a beautiful lawn ranger in Larry's horse barn and it even had oil down the front of the engine I just think its very common thing for the teckys I put a piece of air hose on mine so it goes down to the ground instead all over the motor
Oops meant mid mo meet and great
Don't keep them clear up to the full mark, down just a tad
And that will help a bunch. I think they are splashing oil up around the valve stems
Not so much a blow by thing.
And that will help a bunch. I think they are splashing oil up around the valve lifters and stems
Not so much a blow by thing. Keep mine down a couple ounces after it slobbered
Oil all over the whole front end, oh well a good rust inhibitor up there I guess!
Edited by specialwheelhorse
the crank case is filling up with air clean the crank case filter
Just a thought...,.Could it be possible to run the hose up instead of down? Might not loose any oil at all.
I know mostly my fixes are prob misunderstood on the prob, but if I'm understanding your prob, oil is blowing out of valve breather..correct.
In the past as I've cured this prob, the Tecumseh crankcase breather has a down and an up. There is a return slit or hole that needs located down allowing any oil passing through to check valve dain rather than filling up and blowing past and out. I'll try and find the picture of proper position.
Also:from manual..
BREATHER PASSING OIL
1. Check the oil level, make sure the engine is not overfilled. Also verify that the viscosity rating on the container of
the oil being used is to specification.
2. Check the angle of operation. Avoid prolonged use at a severe angle.
3. Check the engine R.P.M. setting for excessive R.P.M. using a vibratach or other tachometer and compare it to the R.P.M. settings found on microfiche card # 30 according to the engine model and specification number. Adjust the high and low R.P.M. as necessary.
4. Check for leaking or damaged gaskets, seals, or "O"-rings. External leaks may not be evident; however, the leak may prevent the engine from achieving a partial crankcase vacuum.
5. Check the breather for damage, dirty condition, or improper installation. The oil return hole(s) must face down.
6. Check the engine compression using a compression tester. If the engine has weak compression, determine the cause of weak compression: worn rings, leaking head gasket, or leaking valves. Follow the compression tester's procedure
Edited by groundhog47
  • Similar Content
    • By ebinmaine
      I'm accustomed to using Non detergent oil in all older small engines.
      Thanks to @pfrederi I have the manual for the Tecumseh and it says to use detergent oil BUT it is printed in 1998... Over 30 years after DOM on my engine.
      What do you folks use??
    • By ebinmaine
      I've ordered this set
      https://www.redoyourhorse.com/tecumseh-4-pc-engine-decal-set/
      from our awesome vendor Terry @Vinylguy.
      I know where the balloon sticker goes and the oil sticker.
      Where does the large "Solid State" one belong??
      Thanks!!
    • By Team70R
      Looking to get rid of all my Tecumsehs! The HH60 ran before I pulled it, just needed carb adjustments. Electric start! The other 2 appear to be H60s but are both in rough shape. One has a broken flywheel fin, stripped out oil plug hole and a seized governer. Other one has a broken crank or rod. Pm for more details! Pick up only, at this time.
    • By raymondvandervort
      HH60 cast block in very good shape, bead blasted and primed with zinc chromate primer,
      with some valve parts, dimensions available. Part numbers for this block have
      been:32176;32163;31789;32176;32176A;32176B;34761. Prepped for a project the customer abandoned.
      Also parts obtained for this project available:
      Gasket set 33235A
      Breather 28423
      condenser 30548B
      Screw 650697A
      Screw 650694A
      wiper 30549
      Breather tube 35350
      valve cap 30964
      valve cap pin 20810
      gasket 29673
      valve cap 27882
      oil seal 28460
      oil seal 27876B
      carb 631828
      valve spring 27881
      points 30547a
      governor spool 30588A
      breather filter 28424
      bearing 31793
      valve retainer 27883
      bushing 31461
      gasket set 33234A
      rod 31380C
      ring set 34854
      piston 31797B;345503;34531
      Gasket set 33235A
      Breather 28423
      condenser 30548B
      Screw 650697A
      Screw 650694A
      wiper 30549
      Breather tube 35350
      valve cap 30964
      valve cap pin 20810
      gasket 29673
      valve cap 27882
      oil seal 28460
      oil seal 27876B
      carb 631828
      valve spring 27881
      points 30547a
      bearing 31793
      bushing 31461
      gasket set 33234A
      rod 31380C
      ring set 34854
