wheeledhorseman 573 #101 Posted December 13, 2013 For completeness here (and as vertical shaft tractors were mentioned), here's a NOS blade I've just acquired that fits some of the 1980s verticals like my 216-5 and was also supplied for the B-165 with a slightly different lifting rod linkage. Its designated model (VIN) is 06-42BB02 Andy Share this post Link to post Share on other sites
Lane Ranger 10,427 #102 Posted December 14, 2013 Another Snowplow/Dozer blade hookup issue is the Solid Link Piece #7706 (I think that is what jasonracer is referring to back several comments ) that you can use to hookup your Snowplow/Dozer Blade to your Wheel Horse tractor lift to increase Downward Pressure on the front dozer blade. If you Search 7706 Solid Lift Link on this site in the search box a couple postings should come up. Here are some photos of the solid lift link piece: Share this post Link to post Share on other sites
todnep 0 #103 Posted January 14, 2014 I need some help. I'M TRYING TO MOUNT a snow plow on my 1999 wheel horse 312-8 speed and not sure about the mounting hitch or if there is a certain hitch or proper way the hitch gets mounted. can anyone help with pictures or video or anything at all thanks troy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,443 #104 Posted January 14, 2014 There are many blades that will fit but these manuals are for the blade sold for the 312-8 in 1999 Garry Share this post Link to post Share on other sites
shadley88 0 #105 Posted August 29, 2015 (edited) Can anyone help identify this plow? He says its from a early 60's but it looks like a long frame to me. It's on craigslist and the person doesnt have the measurements on it but want to get it for my C120 ASAP !!! Thanks. Edited August 29, 2015 by shadley88 Share this post Link to post Share on other sites
DennisThornton 4,769 #106 Posted August 29, 2015 Can anyone help identify this plow? He says its from a early 60's but it looks like a long frame to me. It's on craigslist and the person doesnt have the measurements on it but want to get it for my C120 ASAP !!! Thanks. Was the width mentioned? I'm guessing you don't have more pictures? Esp of the back end? Right now I think it will fit. Looks like a $100 to $150 plow around here! Cheap enough I'd buy it anyway and do what I had to do. I'm not sure when they changed from the straight A to the A with trailing parallel rails. Hope I said that so it can be understood. I can't access my pictures right now... But hang in there, someone else will jump in shortly. I just know time is of the essence when gathering info to make a purchase on CL! Don't forget you need a rear hitch! Around $50 in this area!Good luck! Share this post Link to post Share on other sites
shadley88 0 #107 Posted August 29, 2015 Can anyone help identify this plow? He says its from a early 60's but it looks like a long frame to me. It's on craigslist and the person doesnt have the measurements on it but want to get it for my C120 ASAP !!! Thanks. Was the width mentioned? I'm guessing you don't have more pictures? Esp of the back end? Right now I think it will fit. Looks like a $100 to $150 plow around here! Cheap enough I'd buy it anyway and do what I had to do. I'm not sure when they changed from the straight A to the A with trailing parallel rails. Hope I said that so it can be understood. I can't access my pictures right now... But hang in there, someone else will jump in shortly. I just know time is of the essence when gathering info to make a purchase on CL! Don't forget you need a rear hitch! Around $50 in this area! Good luck! Yes thank you ! And no width mentioned or any other pics . I pulled those from his posting. It's about an hour drive away but for $40 I hope it works or at least can make it work ! Sent from my SAMSUNG-SM-G920A using Tapatalk Share this post Link to post Share on other sites
DennisThornton 4,769 #108 Posted August 29, 2015 $40 is a no brainer! But keep in mind you will need a rear hitch! Share this post Link to post Share on other sites
shadley88 0 #109 Posted August 29, 2015 $40 is a no brainer! But keep in mind you will need a rear hitch! Yes already have a line on one on ebay , new fabrication. Sent from my SAMSUNG-SM-G920A using Tapatalk Share this post Link to post Share on other sites
