zieg72 209 #1 Posted December 29, 2007 Hello, brand new here. Looking for someone who has a 60" deck on their 520 tractor to look at their mule drive. My belt is wearing because it rides on the outside and shreds the belt. I think the piece that the outer pulley bolts to is tweaked. Can anyone confirm it? Thanks in advance. I have other pictures as well. Attached Image (Click thumbnail to expand) Share this post Link to post Share on other sites
Rollerman 290 #2 Posted December 29, 2007 zieg72 can you give us a better pic..or one showing the whole mule drive? I was under the assumption that all the C's,300/400/500 series tractors used the same mule drive no matter what the size of the deck? Your pic is a little vague I guess. They "mule drives" canbe had pretty reasonable on ebay or repaired too. If your is bent I'd need a better pic to help. Sorry Share this post Link to post Share on other sites
kj4kicks 151 #3 Posted December 29, 2007 Hi Zieg, Welcome to the site! I have a 91 520 that had a 60" deck on it the day I bought it, but not since then. It has a FEL now, so there's no room for the mule drive. Are the bearings smooth on the mule drive? Maybe someone changed one and it's wrong? I have the one off of mine if you need to compare. The good news is, the same mule drive fits all of the 300, 400, and 500 series machines, so they're not too hard to find. I have a spare if you need it. Eldon. Share this post Link to post Share on other sites
zieg72 209 #4 Posted December 29, 2007 zieg72 can you give us a better pic..or one showing the whole mule drive? I was under the assumption that all the C's,300/400/500 series tractors used the same mule drive no matter what the size of the deck? Your pic is a little vague I guess. They "mule drives" canbe had pretty reasonable on ebay or repaired too. If your is bent I'd need a better pic to help. Sorry Here is a picture with the pulley on it. The tab in the first picture is what the outer pulley bolts to. The bearings seem fine. Thanks Attached Image Share this post Link to post Share on other sites
kj4kicks 151 #5 Posted December 29, 2007 I see the problem. The pulleys are supposed to be parallel. The angled piece goes on first, then the pulleys. See what happens then. The belt will naturally be aligned. Eldon. Share this post Link to post Share on other sites
kj4kicks 151 #6 Posted December 29, 2007 A pic of a rough one, but it shows the pulleys: Attached Image Share this post Link to post Share on other sites
zieg72 209 #7 Posted December 29, 2007 I see the problem. The pulleys are supposed to be parallel. The angled piece goes on first, then the pulleys. See what happens then. The belt will naturally be aligned. Eldon. Thanks, I kinda figured that but wanted to ask the experts. I will try and straighten up the tab and see if it works out. Any idea what you might be asking for your extra if I brake the tab off?? I guess I could get a new shaft via Toro but I thought I would ask you first. Also do I have the spring in the right place?? I pick up my plow tomorrow for it, can't wait. Share this post Link to post Share on other sites
kj4kicks 151 #8 Posted December 29, 2007 I don't use a mule drive on any of my machines. My deck is on an old 1077, completely different setup. I don't have a spring, so I'm not sure where it hooks. Mule drives usually go for $20-25 on ebay, depending on the day. The above pic was "borrowed" from a current listing. Ebay Item number: 160193383571 is another one, complete with belt guard. Where are you located? Eldon..... in SE PA Share this post Link to post Share on other sites
zieg72 209 #9 Posted December 29, 2007 I don't use a mule drive on any of my machines. My deck is on an old 1077, completely different setup. I don't have a spring, so I'm not sure where it hooks. Mule drives usually go for $20-25 on ebay, depending on the day. The above pic was "borrowed" from a current listing. Ebay Item number: is another one, complete with belt guard. Where are you located? Eldon..... in SE PA I saw that listing on ebay. I have been looking to see if one shows up on the bay like mine. I just assumed that with the offset design of the pulleys it was just for the 60" deck. I am new to the "real tractors" as my other machine is the "lawn tractor" variety. I have the guard and the part # of the shaft should I break the tab off and can't get it welded on right. I am in NW Indiana Share this post Link to post Share on other sites
kj4kicks 151 #10 Posted December 29, 2007 I have 3 on the shelf. One from a C-160, one from a 416-H, and one from a 520-H, and they are all the same. If you can't find one, I'd sell you one for $25 including shipping. Email me if you need it. Eldon. Share this post Link to post Share on other sites
zieg72 209 #11 Posted December 29, 2007 I have 3 on the shelf. One from a C-160, one from a 416-H, and one from a 520-H, and they are all the same. If you can't find one, I'd sell you one for $25 including shipping. Email me if you need it. Eldon. Thanks, I will let you know. I appreciate your time today, now I got to go outside and work on my other hobby, Chevy Trucks.... Happy New Year, and great site.... Share this post Link to post Share on other sites
zieg72 209 #12 Posted December 29, 2007 I have 3 on the shelf. One from a C-160, one from a 416-H, and one from a 520-H, and they are all the same. If you can't find one, I'd sell you one for $25 including shipping. Email me if you need it. Eldon. One more question, the one from your 520H look like mine or like the rough one in the picture off the e-bay auction, (pulleys on the same shaft)?? Share this post Link to post Share on other sites
nylyon-(Admin) 7,088 #13 Posted December 29, 2007 I could be wrong, and I don't have a 520 or 60" deck, but I had thought that the mule drive for the 60" looked like Carl posted and was different from the others? But again, I don't have one. Share this post Link to post Share on other sites
kj4kicks 151 #14 Posted December 29, 2007 They are at home, and I'm at my store, so I can't get a pic. The pulleys are on the same shaft, and are definetely parallel. Eldon. Share this post Link to post Share on other sites
Nick 13 #15 Posted December 29, 2007 Not sure if they used it from the start with the 60" decks, or on any other decks, but the mule drive on the later 60" deck is spring loaded. Been to long since I used my brothers so cant say if there are other differences. Share this post Link to post Share on other sites
kj4kicks 151 #16 Posted December 29, 2007 My 520 had 1800 hours on it when I bought it, so the mule drive may have been changed somewhere along the way. I'll get pics of them tonight. Eldon. Share this post Link to post Share on other sites
zieg72 209 #17 Posted December 29, 2007 I could be wrong, and I don't have a 520 or 60" deck, but I had thought that the mule drive for the 60" looked like Carl posted and was different from the others? But again, I don't have one. I guess I could look it up and compare part #'s if I knew what the 91 model # was. I am fairly certain mine is original to the tractor only having 424 hours on the clock. Share this post Link to post Share on other sites
Nick 13 #18 Posted December 29, 2007 This is the number I got on the Toro MPV for a 91 deck. C5-60SC03 Share this post Link to post Share on other sites
Jim_M 178 #19 Posted December 29, 2007 I have a 1990 or 91 520-H with a 60" deck and the mule drive is the same as the one on my 416-H, or C series. I have never seen one like this. Share this post Link to post Share on other sites
zieg72 209 #20 Posted December 29, 2007 I have a 1990 or 91 520-H with a 60" deck and the mule drive is the same as the one on my 416-H, or C series. I have never seen one like this. Here is the parts breakdown on the 1991 that the model # was given Attached Image (Click thumbnail to expand) Share this post Link to post Share on other sites
nylyon-(Admin) 7,088 #21 Posted December 30, 2007 I think you have the right mule drive, but what about the belt it, is it a Toro branded belt or aftermarket? Share this post Link to post Share on other sites
kj4kicks 151 #22 Posted December 30, 2007 No way the belts should be hitting the pulleys at that angle. It may be the mule drive that is specified, but something is very wrong here. If you spilt the difference in the pulleys, they would both line up. One with less angle, and one with more angle. I'm voting that you put a drive on there that has 2 parallel pulleys, and the problem will be solved. Karl is also right, make sure to use a WH belt (but that is not the problem here). I'm heading home, and will get some pics, but I can't upload them until tomorrow. I'll chime in again later. Eldon. Share this post Link to post Share on other sites
Jim_M 178 #23 Posted December 30, 2007 I didn't look up the drawing for the part number, guess I should have. Mine came with the style of mule drive that we're all used to seeing. I had no idea there was another style of mule drive until today. Share this post Link to post Share on other sites
Nick 13 #24 Posted December 30, 2007 Showed my brother the picture, think he said the main mounting bolt needs to be removed and turned 180 degrees. If that doesnt make sense I'll ask him again how to fix it. He says they have even seen them ship from the factory that way. Share this post Link to post Share on other sites
zieg72 209 #25 Posted December 30, 2007 I think you have the right mule drive, but what about the belt it, is it a Toro branded belt or aftermarket? The belt came straight from the Toro dealership. Made 2 passes, about 5 minutes of mowing and noticed the stringy fiber coming off the side of the belt as shown in the picture. The drawing posted on the Toro MPV shows an angle, but it is hard to say if mine is extreme or not. Thanks for everyone chiming in. Glad there is snow on the ground and a good 4 months to figure this out. Share this post Link to post Share on other sites
